Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer wont come on have power to it i got one er in display reading now nothing
  • 7 more comments
  • caalde Apr 23, 2010
    had it unplugged did nothing er only came up once when ipushed stop button wont come up again
    unplugged again nothing
    there is nothing on display no red lights no er
    have power to machine
    tried what you said nothing no red dots no lights seems like no power
    there is power to the plug im not sure about to machine but i did get one er message
    what do i do when i get to machine control
  • caalde Apr 26, 2010
    put machine control board on works thanks for help Gary
    got the right answers from Jahn27 Very pleased needed machine control board if anyone else has this problem
    President:
  • 1,554 Answers
Power is disconnected while the washer is in operation and the machine control failed to save the cycle information. The display can be cleared by pressing the STOP/CANCEL button.
Allow the machine to sit unplugged for an hour or so to allow the processor to reset. Replace the machine control board if the display cannot be cleared or if the processor doesn't reset after being disconnected for an hour or so.
Posted on Apr 23, 2010
  • 6 more comments
  • Jahn27
    Jahn27 Apr 23, 2010
    The machine control board is part number 8571359 and it costs about $140 to $160.
  • Jahn27
    Jahn27 Apr 23, 2010
    Does it mean there's no power coming to the machine? Check the breaker for the washer.
  • Jahn27
    Jahn27 Apr 23, 2010
    Activate the automatic diagnostic mode if you are certain that there's power coming to the machine. Press SOAK - SOIL LEVEL - SOAK - SOIL LEVEL within 5 seconds while the machine is in standby mode. The washer will fill , nutate, recirculate, soin, and drain. Observe if these functions are executed.
  • Jahn27
    Jahn27 Apr 23, 2010
    What made you conclude that there's power to the machine when it seemed like there's no power?
    Make sure that 120 VAC is being fed to the machine control and the AC cord and the line filter are not open. If all of these are verified and confirmed to be good then the machine control (part number 8571359) is dead.
  • Jahn27
    Jahn27 Apr 23, 2010
    The Er code indicates that power is disconnected while the washer is in operation. There is probably an intermittent discontinuity in the AC power cord or the line filter. Make sure first that power is coming into the machine control.
  • Jahn27
    Jahn27 Apr 23, 2010
    The machine control is located under the console. You have to slide a putty knife blade between the washer top and the console at each front corner and push the spring clip that holds the console to the washer top. Push the spring clips back far enough to release it from the slots in the washer top.
    Once released, slightly lift the console up to release the mounting tabs at the rear end of the end caps from the slots in the washer top. Lay the console face down on the washer top and the machine control is now accessible.
  • Jahn27
    Jahn27 Apr 24, 2010
    Using a volt-ohmmeter (VOM ) and while the machine is plugged on, check for 120 VAC on the power cord connection to the line filter; replace the power cord if no 120 VAC is present, otherwise check for 120 VAC on the line filter connection to the machine control; replace the line filter if no 120 VAC is present.
  • Jahn27
    Jahn27 Apr 26, 2010
    It's a pleasure to help you. Thanks for using Fixya.
  • 5,081 Answers
You can unplug the washer for 5 minutes and this should reset the system
if you have anything after ER -- please let me know to be more specific..
Please try the thing i have said.
please donot forget to rate and accept my answer
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
My washer is not working it has power but it wont wash it wont rince it dose nothing
Would love to help you but I need to know if it is displaying any error code?
Feb 18, 2015 | Kenmore HE2 Plus Front Load Washer
CD player displays error code: ER-1
The ER-1 code signifies an unknown error. Try cleaning the player itself, as well as cleaning the individual CD's prior to inserting them.
If that doesn't remedy the issue, ask for further help.
Feb 02, 2014 | Dual Electronics XD1222 Car USB Player
Display problem
Not an answer, but I've got ALMOST the same problem. Output is fine, but the meter reads 0000 (both displays). Fixing to open 'er up and take a look - see if I can figure out the problem. If I find anything, I will post the answer here.
Dec 13, 2013 | Agilent E3617A 60 Watt Power Supply
What does er 1 on the dash display mean on a grizzly 700
Er-1
ECU internal malfunction
(output signal error)
No signals are received from the ECU.
May 04, 2013 | Yamaha 2005 Grizzly 660 Auto 4x4
I am getting a reading on the screen of "er 05" i
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Mar 21, 2011 | Precor 9.31 Treadmill
Washer wont finish cycle and display reads "LR"
Hello todd.... This is a common problem with the neptune. It means that the machine needs a new motor and a new motor control board kit. If you are under warranty do a repair. If not, get an estimate before you go ahead and repair it. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
There is an ER message flashing.we tried pressing cancel but nothing happens. it's like all the settings are frozen
This is a Common Error Message. Try to Disconnect the Power Supply, and wait for few minutes, say 30 minutes to Turn it ON.
If still ER message is displayed, you need to Replace either Touchpad or Control Board.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Frigidaire Dishwashers
Washer won't start, display monitor reas
brynice,
Is your machine a FAV9800AW LCD display?
If so here are some links for the SM and parts look up.
The Service Manual for reference. Sears Parts Direct for reference.
If you machine is the above type the issue could be related to the Motor which under warranty for 10 yrs. Could be the Motor Controller which is only under warranty for 2 yrs. Maytag Customer service info is in the SM. They will need your serial number off the machine located on the back of the console right side. If you are not a DIY’er I would call Maytag for a authorized repair service call to check out the failure.
Oct 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Clarification on the 888 display and wont do anything
MAYBE ITS SAYING 666 . LOL
USE HE DETERGENT AN CHECK UR DRAIN PUMP AN DRAIN HOSE, RUN THREW DIAG TEST. IF NOTHING REPLACE MAIN CONTROLLER
May 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
