Question about Water Heaters
Vokera syntesi 29e no hot water - Water Heaters
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Posted on Jun 06, 2009
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Hi. Had a code 10 on my Vokera UNICA HE boiler. This was due to the overflow pipe freezing up. The pipe has been disconnected from the boiler and the boiler pipe is now dripping into a bucket. However, the...
I had the same problem. There's another clear rubber pipe underneath, that runs from the front right to a pump in the middle. I had to pull it off and dry it with a hairdryer before mine would light properly. Blast into the hole the pipe came off too to dry the sensor if there is one.
Dec 20, 2010 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Low hot water pressure .have A VOKERA MYNUTE HEATER
Sounds like you have debris that is caught in the line or calcium buildup that is blocking the line.
Apr 09, 2009 | ACCO Brands Water Heaters
Vokera combi boiler
Feb 20, 2009 | Water Heaters
How to bleed a vokera syntesi combination boiler
I think you mean your boiler needs pressurising firstly connect hose hand tight open the non return valve normally teed into a 22mm pipe then flick the valve lever on the cold supply quick little bursts till you reach your required pressure best of luck
Nov 15, 2008 | Water Heaters
Water Heaters Logo
131 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
