Question about LG WM1812C Front Load Washer
Clothes come out wet and soapy
We have an LG front load washer and we noticed that our clothes are coming out wetter than normal and their is excess soap in the machine and on the clothes. Does anyone have any idea what we may be doing wrong, or is the washer having technical issues. We are running it on the "normal cycle" with cold water, and using one capful of high efficiency laundry detergent as it says on the bottle. Thanks for any input.
  • Anonymous May 15, 2008
    no draining of water
    President:
  • LG Master
  • 2,651 Answers
Check your manual for cleanout procedure for pump assy. the lower panel acess left side, perahps theres debris in pump no t alllowing proper drainage of water
Posted on Mar 23, 2008
6ya staff
SOURCE:
Clothes are still wet after full spin cycle
Possible that the SPIN Speed is too low, check the drive, the RPM of the motor. Check for friction of the spindle , check for free movement of the drum. If you notice a change then you will need to reset the mechanism. If the motor speed is low check the capacitor.
Jan 24, 2013 | Hotpoint WMA64 Front Load Washer
I have A ge DBXR463ED2WW .it takes about 80 minutes to dry A load.dryer seems to only have A fourth to half heat.
This could be the clothes are coming out of the washer wetter than normal, or poor air flow. 80 min in a little long but a lot depends on the wetness and amount of clothes. If the vent system is clear then I would try smaller loads and checking the washer.
Eric
Jul 21, 2010 | GE DBXR463EDWW Electric Dryer
Bosch Vision 300 DLX WFCVC3300UC I have a new Bosch front load washer and I am wondering if it is working correctly. How can I tell if the spin is working as well as it should? I have tried several load...
it sounds like ur tub is slipping and loose it should be under warranty save ur self a heADACHE AND CALL THEM and tell them it isnt getting ur clothes good enough they r coming out wet
Feb 25, 2010 | Washing Machines
My washer seems to be functioning normal, but my clothes are coming out wet enough to ring water out of them. I have to run an extra spin cycle and they still come out wetter than other machines I've...
The drive belt may be slipping.
There is an adjustment on the motor (four bolts which secure the motor) If you increase the tension on the belt and pulley, you will get a better result.
Ask me if you need more instructions on this.
Ash
Oct 22, 2009 | Asko W6021 Front Load Washer
Stains on clothes coming out of the LG washer
are ther brown stains if so the bearings are faulty.
Jul 07, 2009 | LG WM2455 Front Load Washer
The word "suds"
to much detergent...with theses unit you must use he or low suddsing detergent..take half the wet soapy clothes out then start unit..sud level must fall...
Dec 27, 2008 | Maytag MAH8700A Front Load Washer
Fixing lg whasher
??? not enough information, what do you mean by this? the clothes are still wet when they come out the machine does not spin at all?
the machines have a set time to drain before they spin usually three minutes if the water has not dropped below a level before the set time the machine will stop, check the drain
Clothes begin to get wetter than before? how old is the machine motor brushes usually last 2-3 years depending on usage when they wear down the parts of the program that put the most power through the brushes can fail first (Spin)
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
LG WM1812C Front Load Washer Logo
91 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
