Question about Jenn-Air JMC8130DD Microwave Oven
Model M4188 will not heat starts up .
I have a Whirlpool old model # RM278BXV-3 and it has started shutting all the way down when heating things up. Contol panel goes blank and quits heating.
Sounds like the control panel. All the other parts are just brute force parts and either work or they don't. Over heating components on the control board are the probable cause.
Dec 30, 2014 | Whirlpool Microwave Ovens
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
It started by not heating, then it produced aloud sound that was accompanied by smoke. Now iy cuts power whenever you put it on..
Hi.
Not heating could have started because of a defective magnetron, diode or capacitor. The smoke is consequence of a short that now is preventing the oven from starting.
Please let me know if you would like to get more help on this and let me know the appliance's model number.
Regards.
Ginko
Mar 28, 2011 | Microwave Ovens
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
THERE ARE NO HEAT WHEN I START MY MICROWAVE ALL
Hi! it seems that your microwave oven, magnetron is not working, check the fuse.
Sep 12, 2009 | Microwave Ovens
Amana Model MVH210E The unit turns on and starts up normally but it does not heat and seems to make an increased vibrating noise
I'm having the same problem. When I hit start, the light and fan comes on but no heat. There is not a turntable in the MVH210E model. Any ideas how to fix it?
Jun 06, 2009 | Amana AMV4204A Microwave Oven
Oven humms and doesn't heat anymore....
if you say 'seems like common problem with this model' then just replace it and get another good model.
it gives peace in long run.
May 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Jenn-Air JMC8130DD Microwave Oven Logo
32 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
