Question about Aironet Cisco AP4800
How do I return the default configuration - Aironet Cisco AP4800
  • 12,061 Answers
Www.mikrotik.com/testdocs/ros/2.9/interface/aironet.pdf
Maunal above, usually, at the rear is a small hole, you insert something into the hole and push the button, with the power removed. This resets the router, and next time you try to login, it will be at the default, login, and Password, ALL settings will be returned to as it was when first used.
Posted on Apr 23, 2010
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer:
A.- Using the control panel
B.- Using the web server
C.- Using the Jet Admin Utility
We'll deal with the contro panel setup.
To access the contro panel menus
1. Press OK (Check Mark) button once to access MENUS.
2. Press Up Arrow or Down Arrow buttons to navigate the listings.
3. Press OK (Check Mark) button to select the appropriate option.
4. Press Return to return to the previous level.
5. Press OK (Check Mark) button to exit the menus
So to configure IP address:
Press Check Mark
Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows)
Navigate to the I/O Menu
Navigate to the EIO 1 menu
Navigate to TCP/IP
Navigate to BootP entry
Press Check to disable it (Off)
Press return
Navigate to IP Address, press Check
Use Up/Down buttons to change the address, check to move between octets.
When finished, press Return
In the same way, enter Mask and Default Gateway
Press Return until you are out of the Menus.
Done
Jul 30, 2014 | HP DesignJet Office Equipment & Supplies
How to factory default Procurve 224M J3299A using console and/or Reset/Clear
There's a reset button on back. When pressed in a specific pattern the switch is returned to the factory default configuration. Chapter 8 discussed this in the following manual:
ftp://ftp.hp.com/pub/networking/software/59672145.pdf
May 07, 2014 | HP ProCurve 224M (J3299A) Networking...
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
I want to reset my printer, HP Laserjet P3015 to default, like as if it were a new printer with default settings.
Press the Menu button c01779038.gif , select the CONFIGURE DEVICE menu, and then select the RESETS menu. RESTORE FACTORY SETTINGS. Clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Hope this helps.
Aug 06, 2011 | HP Laserjet P3015X Printer
Hi, could you help me connect to default gateway when setting up a router. I tried connecting to http://192.168.2.1 but doesn't work. thanks.
Hello! Try to configure your network card`s IP address to 192.168.2.x (x = 2-255) and make sure the router is reseted to its defaults. To do this go to Control Panel > Network and Sharing > Change adapter settings and then right click on your network card > Properties, highlight IPv4 and click Properties. You just need to enter the IP and the Subnet Mask. After you`re done configuring the router change everything back to defaults.
Mar 13, 2011 | Computers & Internet
Lost my passphrase
You'll have to reset your router to factory defaults and the configure it all over again.
To perform the factory reset, press and hold the recessed "RESET" button on the back of the router for 15 to 20 seconds. This will return the router back to default factory settings.
Use the web interface or the software that came with the router to configure the router again with a passphrase and change the administrator password.
For more detailed instructions, read the user manual.
Dec 30, 2010 | NetGear WNR2000 Wireless Router
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Tally 2240/9 printer returns to contiunous after I reswet to single paper
This is a common problem with the tally printer line in that model. You have to go into the configuration and set the Single sheet as the default paper style. When you make this selection from the selection menu it will go back to default after a period of time or anytime there is a jam or power off condition to include power saver. Check the user manual for the configuration access to the default settings and set single sheet feed as the default. That will solve the problem.
Jun 23, 2010 | Tally T2240/24 Matrix Printer
Aironet Cisco AP4800 Logo
156 people viewed this question
Top Aironet Computers & Internet Experts
David Payne
David Payne
Are you an Aironet Computer and Internet Expert? Answer questions, earn points and help others
