Unable to connect my laptop to my Wireless Router Wireless Access Point is enabled Using using exact security key, my laptop is Instantly saying it is unable to connect i have tried resetting the router to factory defaults to no avail how can i get the laptop to connect? has not been connected to the internet before by cable but can be connected, should i try that?
  • 1 more comment
  • Christopher Frost
    Christopher Frost Apr 23, 2010
    its not my laptop thats the problem i tried a working wireless adaptor on my comp and it still wouldnt connect which leads me to believe its the router, had the router for a while so ima call my ISP and see if they will replace it
    has to be a faulty access point
  • Christopher Frost
  • Christopher Frost
    thanks ill get it replaced :D
    President:
  • 4,070 Answers
Hi! Sometimes the wireless function of the router really gets faulty. Like mine, I use to have a wireless connection but now Im using cable for the wireless is busted. Replacing the router will only be the solution. Try cable for now. HOpe this helps and have a good one!
Posted on Apr 23, 2010
Unable to connect to the access point
Hi tissa,
I see you are unable to connect to your Access Point as noted on the question provided.
First console cannot connect to an Access point if it is Password protected.
You will need to disable the Password or Network Access key from your Router to be able to get your DSi to connect to your Access Point freely.
To get security with your Nintendo DSi connecting to your Access Point in your Router setting you can enable the MAC Address filtering and get your devices MAC addresses and have it registered or input in your Routers MAC Address Filtering to be able to get your DSi connected wireless and at the same time have your Laptops and other wireless devices connected.
for the MAC address you can call you Internet Service provider on the issue to give you detailed info on how to access you Router settings for the said connection.
I hope that this will help.
Thank you fo choosing Fixya,
mvincentc
Jul 15, 2011 | Nintendo DSi White Console
I want to know how i can make my Linksys Router WRT160N work as access point
By default Linksys router behaves as Access point. On some router you have to enable the wireless function.
So the following to configure the router Wireless Access Point
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts. You can connect as many devices as you wish since it is a access point
Thanks
Vote me If it helps
Apr 26, 2011 | Linksys WRT160N Wireless Router
Unable to connect to access point not the correct security key. need security key.
If you need to get Information about your Security key, you need to access the GUI of your access point of wireless router by connecting to it using the default gateway. Then after taht you can get into the page where you can get teh security key. Cheers!!!
Sep 02, 2010 | Computers & Internet
I have cable from wall to comcast modem ethernet to belkin wireless surf router then to my home pc. I am unable to get online with my laptop.
First make sure your wireless network driver installed on laptop. You can check it in network property.For that press windows key +R key so you can see wireless local are connection icon if it is installed then right click on it and enable if it is disable then again right clicck then click on connect then if in your belkin router wireless enable then you can see your router network there.Then connect it. But if your wifi network icon is not there then you need to install it's driver also make sure on your laptop wifi switch is on you can turn on it with FN key + F5 key too. If you want to enable wireless in router follow below . Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless and enable it then save settings and restart router. You can also set wifi security code in wireless security enable WEP then enter code it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Jul 15, 2010 | Computers & Internet
I can't find a compaible access point on my ds I'm playing animal crossing wild world I try to connect but it says Error code: 51099
Error Code: 51099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
Jun 05, 2010 | Nintendo DS Lite
CANT GET ON INTERNET
Error Code: 051099 This error code can occur for two different reasons:
May 28, 2010 | Nintendo DSi Blue Console
Broadband wireless adapter limited connectivity issues
If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default: 192.168.1.254).
2 On the Home Network menu, click Wireless.
3 In the upper-right corner, click Details.
4 The wireless Access Point page appears. Under:
- Configuration, you can find the network name (SSID).
- Security, you can find the encryption.
On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
Nov 27, 2009 | Computers & Internet
Need a network key
Since you want to access the router setup page and get the wireelss security for your laptop you can try this:
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
When you're already on the setup page of the router youc an go to Wireless tab and click on Wireless security and there you can find the security key that you need....
If the default password didn't work you need to reset the router by pressing the reset button for 15 seconds so it will be back to its default settings with default password which is admin.
But if you successfully log in to the router page just go to the Wireless tab and there you can find all the wireless settings of your router including the wireless security key...
Nov 28, 2008 | Linksys Wireless-G Broadband Router
We need to know how we can do the conection to wireless network. We are only conected by ethernet cable but we need to be conected wireless. We have two laptops at hope.
your laptop must have wireless adapters and you should be using a wireless router or a wireless access point. if you're already using those devices, your laptops should automatically detect the wireless signal (look for the wireless icon, ususally it's located at the bottom right hand corner of your screen if you are using windows but if you're using mac, you need to enable the airport) and you just need to connect to it (note: you should enter the correct wireless password/network key if it's enabled on your wireless router).
hope this'll help you but if you have other concern, just give the exact model of the wireless router/modem/access poitn that you are using and the wireless adapters installed on the laptops
ciao!
Aug 23, 2008 | Computers & Internet
My wireless lose the pasword key
-You need to access your router user interface using a wired pc to the router, by typing the router IP on the address bar of your browser then it will ask you for a username and password.
-Then on that page you will have options where you can enable again the wireless security just enable again the security from that there.
May 06, 2008 | SMC (SMC2555W-AG UK) 802.11a, 802.11g/b...
Computers & Internet Logo
David Payne
David Payne
