Question about Amana ARB9059CS Bottom Freezer Refrigerator
Freezer is fine fride does not work. the dooor was open all night amana arb 905
  • 4,070 Answers
With the door being open so long all the excess moisture iced up the evaporator coil behind the rear panel inside the freezer blocking the air flow. When it automatically goes through a defrost cycle the ice will be melted. If you cant wait you can defrost it with a hairdryer if you remove the rear panel. It should defrost again in a day or two on it's own according to what type of timer you have. With the electronic models you can force a defrost. Look in the manual to see how to to this.
Posted on Apr 23, 2010
Arb - Engel 40ltr not working with dc cord
when you crushed the cord you mite have shorted something else out so you mite have to call a technician out .
Feb 18, 2013 | Engel 40 Qt. Portable Fridge / Freezer
Amana. Buzzing and humming. Does not stay cold. Ten hrs old Amana ARB 2217CS
It sounds like some packing material was left in the unit. You will need to look in your manual and look for set up instructions, since you probably have some packing material left on.
Jul 14, 2011 | Amana ABB1927DE Bottom Freezer...
Amana refrigirator bottom freezer moderl ARB 2214CW it leacks water on the bottom onto the floor it pudles in small amounts all the time at first I thought I spilled somthing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
AMANA---MODEL # ARB 1917CC-22.8 CF..\r\nBOTTOM
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 07, 2010 | Refrigerators
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
Good day,
If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
Dec 21, 2009 | Refrigerators
Our refrigerator is not cooling at all. The freezer is working fine, but no cool air is getting to the refrigerator section. A couple of weeks ago, this problem happened after the freezer had started...
Some fridges only cool the freezer and an evaporator fan motor moves cool air from the freezer to the fridge side. If this fan doesn't spin very freely then it may need to be replaced. You should also pull out the fridge and see where the drain hose is connected to the inside of the fridge, try pouring hot water down the hose to see if it is open. It may be clogged with a pea or some food or frozen. If your fridge is really full, make sure there is nothing in front of where the evaporator fan blows air into the fridge. Make sure that the adjuster flap is open in the fridge section.
Oct 31, 2009 | Refrigerators
Just stopped working: plugged in,light on,fan blows in freezer-
defrost timer probably failed in defrost mode go online search for defrost timer location and manually advancing or initiating a defrost cycle , it may pop into run mode and tell you thats what it is , 90% of the time thats it and they are cheap !
Aug 23, 2009 | Amana ABB1927DE Bottom Freezer...
Fride not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 04, 2009 | Amana ARB9059CS Bottom Freezer...
Amana ARB9059CS Bottom Freezer Refrigerator Logo
194 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
