How do I set my Xerox 425 Document Center back to factory settings.
  • 12,061 Answers
Download.support.xerox.com/pub/docs/.../dc440_432_425_SAG_en.pdf
download.support.xerox.com/pub/.../dc440_432_425_UG_en.pdf
www.partsdrop.com/techinfo/enx_DC220cop1.pdf
Above are the links for the manuals, inside these manuals, is how to do what you want.
Posted on Apr 24, 2010
Reset to factory settings xerox phaser 3250
Reset to factory settings xerox phaser 3250 - Fixya
www.fixya.com/.../t12176778-reset_factory_settings_xerox_phaser_325...
Mar 26, 2012 - A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without ...
Mar 26, 2012 | Xerox Office Equipment & Supplies
I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Jan 16, 2011 | Xerox Office Equipment & Supplies
1) I have XEROX Document Centre 425DC, when ever I take a copy I find black lines on the print , Even on the blank paper 2) When I bought this machine I was told that this machine can be connected to the...
First of all clean the platten glass, also the narrow glass to the left of the platten glass. If the lines are still there after doing a copy,open the upper left cover and look at the fuser heat roller,the lines could be from a toner contaminated heat roller,this can be cleaned with a minerised scowering pad.with the copier switched on press the Key button then # 1 1,touch Enter on the touch screen.touch HSFI tab,scoll down to copies on cru and enter, if the count is above 20,000 the fault could be the cru ( copy cartridge) needs replacing as it is not cleaning the drum.
There is not a USB port on the 425 dc. If the copier has a ESS on top of the engine ( you should see a floppy disk drive slot on the front of the copier) it means it has been converted to a 425 ST, if not it will cost a to much to convert. A xerox 425 ST will connect to a computer. Xerox ST copiers means Networked
Jan 15, 2011 | Xerox Document Centre 420 DC Laser Printer
My Fuji Xerox C525A constantly says that the bypass tray is empty when it is not. I have to remove the paper and slide it back in and it will print 2 pages and then I have to remove the paper and slide it...
make sure you have the right paper size settings. The paper loaded in the tray might be shorter than the setting in the document. Check also the output size in printer setting.
May 20, 2010 | Xerox DocuPrint C525A Laser Printer
Xerox Document Center 440 replace cartarage every 4 coppies
just Check The Wiring of dc bord
in back side of a printer.
Dec 28, 2009 | Xerox Document Centre 265ST Printer
Master Reset to Factory Settings - Xerox 432
Yes, you have to go into the service settings and reinitialize the memories. I have to look it up but I will send them to you tomorrow.
Dec 10, 2008 | Xerox WorkCentre 432 ST Copier
Fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Aug 02, 2008 | Xerox WorkCentre M123 Copier
How can I avoid printing a cover sheet every time we print on a 265 st xerox document center
You have to enter the customer settings, access button then 11111. Scroll around until you find the location to turn OFF the cover sheets.
You also MUST have cover sheets disables on ALL conputers connected to the machine. Somehow if someone on the network has the cover sheet turned on, it will sometimes enable it on the machine also.
It is called BANNER sheet in the memory.
Jul 15, 2008 | Xerox Document Centre 265ST Printer
104 people viewed this question
jasbo
jasbo
