Below are instructions that I have found from the internet. Hope that they will help.
Open the front cover of the printer.
Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
Remove the drum unit and toner cartridge assembly.
Replace the drum unit and toner cartridge assembly back into the printer.
Close the front cover of the printer
Your drum unit should now be reset
MFC / DCP PRINTER SERIES
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
3.The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. We need to reset this now!
4.Open the front cover of the printer
5.Press and hold down Go button for about 4 seconds until all the LEDs light up.
6.Once all 4 LEDs are lit, release the Go button
7.Close the front cover.
with the front cover still open press "clear/back." it will ask if you are replacing the drum unit. press the up arrow to indicate yes. wait till it says accepted and then close front cover
