Question about Cobra 29 LTD CB Radio
I have a cobra power mic that has no audio output
I have a cobra power mic that keys up the radio but no audio comes out. i switch to a regular cobra mic and the audio works fine.
  • ddknzz Apr 26, 2010
    i have 3 of these mics and ALL the wiring is correct as you have listed to me. BUT i still have no audio out of any of them. i am wondering if there is a transistor blown in them ???????? i'm not sure of the workings of a power mic. Thanks, Dave.
    Genius:
  • 1,274 Answers
Sounds like its not wired up right, the audio wire must be off,take the plug apart and check the white wire, re-solder it. here is the wiring, pin1-shield,pin-2audio-(white), pin3-transmit-(red), pin4-receive-(black).....hope this was helpful...
Posted on Apr 23, 2010
  • JOHN BABA Apr 26, 2010
    Check to see if they work on PA, if they do work, then it could be in the audio chip, or other ....does it recieve ok......
My cobra 142 gtl loses power about two minutes after keying the mic.
hi
it looks like the output stage is going hot (99%)
maby the swr is high end eficiancy is low
usualy on ssb the power is higher than on am
bernard
http://www.rylwy.com/
Aug 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 18 wx st receives-wont transmit
Take the cover off, flip it over solder side up, check all solder joints for cracks, cold solder joints, check the safety diode where it comes in the radio, before I go further, can you pick up the weather channel?...Does the PA work?...need to check the pre-driver and finals,audio chip, hook up the power meter using a coax three foot jumper from the output from radio to the input of the watt meter, then the antenna, first check the SWR, on the scale on the meter to cal/swr mode,adjust it to spec, then while still keyed down turn the dial to SWR,if it is the safe range your ok,then turn the Dial to 10 or 20 watt scale and key the mic. Does it have any wattage? If not suspect the finals, they are located on the back rail, if it does have RF then its the audio chip, its located on the right side rail facing you,closest to you.remove it and replace it with same ....hope this helps....
May 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
No modulation with strong carrier
sounds like your Audio Output went out......not audio chip....may be your voltage regulator also....your voltage regulator IC is heat sunk....do you have a schematic?
Jan 23, 2010 | Cobra Radio Communications
Where does the pin on a mic go to on a cobra 29 ltd
1/ shield 2/ audio (usually white,it's the wire the shield is wrapped around) 3/ red 4/ black if the radio transmits without keying the mic. switch # 3 and # 4.Good Luck
Apr 25, 2009 | Cobra 29 LTD CB Radio
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
No transmitt,Key up and meter pegs out.
The problem is the audio output chip. the number of this chip is TA7222AP, have this chip replaced and it will solve your problem. If you need futher info contact me at : outlaws_cb_shop@yahoo.com
Sep 09, 2007 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
156 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
