Morning. I have a zebra printer and the labels are printing with a very small font. Is there a way to adjust the size?
5 Suggested Answers
SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Posted on May 19, 2008
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
  • 6 Answers
SOURCE: Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Posted on Sep 25, 2008
henkszx
  • 6 Answers
SOURCE: when print button is pressed my printer prints a tiny font
Hi..
you must use the right driver, uninstall the old one and try to reinstall the driver again
good luck
Posted on Nov 06, 2008
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
How to change the font size in ZEBRA 220Xi4
You would change the font size in the label design software that you are using. Click on the text box and then adjust the font and font size.
Jul 08, 2011 | Zebra 220Xi4 Thermal Label Printer
Font height is big in printed barcode. how can I adjust the size of the font?
check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
Dec 05, 2010 | Zebra Z4Mplus Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
Sizing and Orientation problem on Zebra 140 Xill
As far as the size it sounds like it might not be using the right resolution these come in either 200 or 300 DPI. Make usre your DPI is set to the same as the printer. If the printer is 300 and the design shows 200 then it will print rather small on the label. Not sure about the other issue.
Mar 17, 2009 | Zebra 140XiIII Plus Thermal Label Printer
BAR CODE FONTS FOR LITTLE LABELS
Depends on what software you are using, but you can use any True Type Font for the human readable, and any propritry barcode font available as downlaods.
However these barcode fonts tend not to print very small, it is a matter of trial and error.
www.lancerlabels.co.uk
Feb 10, 2009 | Zebra TLP 2844-Z Thermal Label Printer
ZEBRA 105SE
The label sensor is not detecting the gap between the labels.
Make sure the labels are loaded all the way to the left (as viewed fron the front) and make sure the label guide (near the back of the printer) is set to keep the labels from wandering away fromt he sensor.
There is a pair of infrared emiter and detector located above and below the label path. As label pass between, these measure the leading and trailing edges of each label.
If you haven't already done so, calibrate the printer, by using the "Online", "Calibrate", "Online" buttons. If the "Feed" button doesn't feed just one label, you'll need to adjust the label gap sensors. This can be a bit trick if your labels are very narrow.
There should be a small pcb on a shaft under the label path. Note its current location, then slide it left or right to get a better signal, and try the feed button again. On my Zebras, the sensor is not in the middle of the PCB. Look for a small metal "can" on the PCB and center that.
The upper sensor is more difficult to adjust, but if you manage to spot a very small PCB above the labels, it will be easier to line these up.
If the labels are extemely
Sep 04, 2008 | Zebra 105Se Thermal Printer
Hi Burgymon,
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Mar 21, 2008 | Zebra 105SL Thermal Label Printer
k24674
jasbo
jasbo
