Question about Konica Minolta Magicolor 2530 DL Laser Printer
Paper stuck at back
I have a sheet of paper stuck between the rollers at the back. I can't find a way of manually rotating rollers, which means that I tear the paper as I try to pull it out. Can you help???!
Thanks, NP
vijay
  • 27 Answers
SOURCE: Paper jamming, not feeding through evenly with rubber rollers
clean the rollers with propanol whcih is available small bottles with hardware vendors or with chemists. clean the rollers carefully with that try a print. if it not works then consult your service centre.
Posted on Apr 06, 2007
  • 214 Answers
SOURCE: Minolta 2350 DL laser printer stuck paper in rear user roller
sry, dont understand, where is the paper jam, in the end at the fuser ? or some where else?
Posted on Feb 09, 2008
SOURCE: Hi I have a Canon PIXMA
It is fixed, I think. My husband worked on it today and had a look inside the printer with a flashlight. He found a plastic tack had dropped in the rear of the printer, down in the rollers! So he fished it out & we seem to be up & running!
Thank You! Joann Gabriel
Posted on Nov 13, 2008
digitrics
  • 14 Answers
SOURCE: paper jam back door of Lexmark T640
Hello there,
Since you are not able to grab the paper from behind the printer. It make sense to believe that a major part of the trailing edge of the paper is still inside the printer. I would suggest you to open the front cover, remove the toner cartridge and check out if you could try removing the paper from inside. If this doesn't help you might want to remove the redrive assembly (the back portion of the printer) which can be taken off by removing two little screws on it. These screws are located very close to the backdoor which you opened up. Once you remove the screws, press either sides of the latch which is present on the top of the redrive assembly. Hope this helps!
Merry Christmas!
Posted on Dec 20, 2008
SOURCE: Paper Feed errors on 2400W
Thanks to the Konica Minolta tech: Solution is to use alcohol and a clean wipe or cue-tip on the grey 1/2 moon roller deep inside at the end of the paper feed tray. It is accessessible easily by lifting blue top cover of printer, then pulling out the ink cartridge. There will be a grey 1/2 moon like roller seen when looking at very bottom of cavity. Clean the dust off and all will work fine. You can manually roll the roller to get all faces. The machine will reset it's position so it is not nessary to set back to original position.       Turn the machine on with or without paper. Once the roller has reset it's position, gently push the load of paper into the paper tray to be sure the roller was not keeping the paper from being placed to furthest position toward back of tray.
     All is ready for reliable printing once again! Best regards, Danny
Posted on Jan 12, 2009
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
    Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
    If you do not have a manual it can be downloaded from here:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
    Issue: More than one sheet of paper feeds while printing
    Solution: Clean the paper feed rollers using the MX300 operator panel
    sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
    1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
    2. Clean the paper feed roller.
    (1) Press the Menu button repeatedly until MAINTENANCE appears.
    (2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
    The paper feed roller will rotate as it is cleaned.
    3. Repeat step 2 twice.
    4. Open the Paper Output Tray.
    (1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
    (2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
    5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
    Set the Paper Thickness Lever to the left.
    6. Repeat step 2 three times.
    The paper cleans the paper feed roller as it feeds through the machine.
    If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
    Dec 25, 2010 | Canon MX300 Office All-In-One Printer
    My canon pixma MP210, is not feeding the paper through, seems to jam, but printer still is printing. The paper is taken about 10cms into printer, then twists slightly but does not fee through. Have checked...
    There is a foreign object in the paper tray. Because it is curved you cannot see it. It is stuck in the narrowed area right before the feeding rollers.
    Disconnect the cables and rotate the printer in a way it stands on its back.
    Open the front cover. Use long thin flat screw driver that can go trough the paper out area and to reach the feed roller.Insert the screw driver between each pressure roller and the the feed roller to release the object. If successful it will fall out from the tray. Usually it's a coin, pen, point-protector, ruller, paper clip and so on.
    Aug 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    In my 3530 single side copying is ok but when i am trying for back to back my A3 paper is getting jam with z fold pls guide
    are you talking about ir 3530 b&w copier?
    "Z FOLD" of jamed paper is usual when paper goes from cass. towards registration roller, and registration clutch doesnt operates.
    Do you have problems with A4 double sided too?
    Where does the jam occures? In wich section?
    I had few cases, when the paper stucked above fixing unit in small inner door, wich guides paperout or back in duplex, for second side copying.
    The problem was in spring and solenoid wich lifts the paper guide plastic with finger.
    It also could be case that you need to replace paper pickup, feed and separation roller in cassete where is A3 paper, and clean other rollers.
    Try to put paper in "good" cassete, from wich you do not have problems.Just swap papers, and set correct paper sizes, and if it works then the problem is 70% in rollers.
    On the place where the paper stucks, clean the paper rollers, by rotating it and cleaning with alcohol or water and dry it verry well.
    Hope that helped.
    If you have more questions or want service manual, write on emma.servis@gmail.com
    Jul 09, 2010 | Canon Office Equipment & Supplies
    My Brother MFC-7820N has trouble picking up sheets of paper
    Hi! I just recently noticed that the 7820N has an "extension" piece at the back of the paper tray. This extension should be pulled all the way out and the blue paper stop adjusted accordingly. Otherwise, the loose extension piece will slide out from the rear of the printer when the tray is slammed in, and the paper will not be where the the printer expects it to be.
    Other than that, check that the pad at the front of the tray is clean, and that the plastic small roller next to it rotates freely. Also, try cleaning the rubber rollers that are located inside the printer above the tray with a damp cloth.
    Apr 02, 2010 | Brother MFC 7420 All-In-One Laser Printer
    Does not pick up paper from the tray
    How much paper gone throught the printer since it is new?
    usually the pickup roller is good for 10,000-15,000 sheets.(20x500 sheet pack). if the printer went throught that much paper, then the pick up roller need to be replaced.
    if not, make sure there nothing stucked on the pickup roller, and the roller is not shining (it need to be soft and rough).
    Apr 18, 2009 | Dell 1700 Laser Printer
    Konica Minolta Magicolor 2530 DL Laser Printer Logo
    15 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    David Burkhart
    David Burkhart
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
