Question about Fisher Paykel EcoSmart GWL15
Washer starts up but sometimes keeps stopping and has to be restarted or skips cycles. Will replacing electronic board stop this?
  • 713 Answers
Hi,i think the problem you are experiencing is a pumping issue.
1.Check the hose to see if it has a kink in it,
2.Access the pump by unscrewing the cover behind the unit,probably there is a small object caught in it and it wont turn the machine senses , and this will cause it to stop in the middle of the cycle.
Thanks and take care
Posted on Apr 23, 2010
Washer wont complete cycle
Sound like the control board is bad
Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
Whirlpool Duet Sport Model WFW8300SW00 stops after spin cycle
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2010 | Whirlpool WFW8300S
I have a Kenmore Elite Washer it stops alarms and shows F1 error, we are able to turn off the washing machine and restart, it works for a while but this problem continue to happen
May 02, 2010 | Kenmore Elite 45986 Front Load Washer
Will not pass the spin cycle
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$!$!$
Apr 08, 2010 | Kenmore Elite 45986 Front Load Washer
WATER SHUTS OFF WHEN STARTED 3 TIMES
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$@#$
Apr 01, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Quietpak 2 washer keeps giving
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$@@$$
Oct 21, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet front loading washer just stops in middle of cycle, flashes f. keeps happening
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer stops during cycle
Do a visual inspection on the electronic module. To do you need to removed it. Follow the manual for this. I got the manual from, it's pretty big, about 44MB: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/07e2c9ebdcf04a3085256f38004f9b84/$FILE/WPWASHER1.pdf
I had the same kind of issue on mine, no spinning and occasionally it did not want to start. I decided to remove "electronic control module" and do quick visual inspection on the board.
I find out that the board was full of little (microscopic) lead (plumb). I cleaned it with a toothbrush and ALCOHOL on both side, re-installed it and since then the machine worked find... Finally after a year I have a working machine.
I think you should test this solution before spending $400 on a new "electronic control module".
Let others know if it work on your side too.
Aug 07, 2008 | Whirlpool LHW0050PQ Front Load Washer
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Dishwashers
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
