Question about Garden
REQUIRE A MANUAL FOR PW9TSS JCB PRESSUREWASHER
Pressure washer wont take in soap from bottle
4 Suggested Answers
SOURCE: Where can I purchase a replacement soap bottle?
Contact:
Roberta's, Inc.
24 W. Franklin Street
Shelbyville, IN
46176
(800) 428-9726
(317) 398-4453
http://www.robertasinc.com
Posted on Sep 05, 2009
  • 832 Answers
SOURCE: The motor works fine , no pressure out of hte
Since you did not mention the pump brand or type. I will just assume it to be a pressure washer, complete
with gun. The pump comes two suction hoses. One for the water supply and one for the soap bottle or pail There is pressure adjuster right at the pump near where the hose is connected. You can adjust to higher pressure by turning it clockwise. You can adjust the nozzle spray pattern by turning it. However, if your pump comes with only one set of suction hose. Then, it is designed to get the water
supply from the faucet with hose bib. The only one
set of hose is for the soap bottle or pail. It will **** the soap once the nozzle spray is opened.
hose,
Posted on Nov 01, 2009
SOURCE: Can' get the soap to go in my pressure washer
I dont know about your system but you probably have dirt in your suction valve venturi or injector valve.
Posted on Aug 28, 2012
Adjust soap injector
If it connect to the outlet pipe/lance then it operates on SUCTION similar to blowing across the top of a beer bottle to make a noise. If thats the case it is a matter of blockage and ventilation of the soap bottle to allow air to enter as the soap is sucked out by the water flow.
Oct 23, 2015 | Northstar Pressure Washer 3000 PSI
How to get my soap pickup to work
The plastic soap bottle has a rotatable ring around the neck. Rotating it regulates the amount of soap flow. Clockwise increases the flow and counterclockwise all the way turns off the soap completely. There is an arrow and incline cast into the ring indicating more or less soap.
Apr 23, 2015 | Garden
Craftsman pressurewasher
What is the pressure washer problem?
Aug 17, 2014 | Garden
Soap attachment
if the bottle is external ,attach hose supplied to bottle and pump. soap will only work when low (big hole)nozzle is used.
Apr 18, 2014 | Garden
HOw to attach soap bottle to earthwise 1850 pressure washer
It should have a tube on it put it in your bleach bottle and use the black tip for dispense 1/2 bleach/1/2 water
Aug 08, 2013 | Earthwise 1850 PSI Electric Pressure...
Pressurewasher
you may of already tried this but is there a water flow back connection on the hosepipe? has it been connected to the end that fits onto the pressure washer? we had this same problem when it was connected the wrong way round... the flow back stop connection should be tap end...hope this helps...:-)
Feb 07, 2012 | Electrical Supplies
Solutions won't feed from bottles on machine? I use the switch on this machine to use a deck cleaning solution and the bottles won't feed the solution into the water.
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jun 25, 2010 | Campbell Hausfeld 1800 PSI Electric...
Soap doesn't dispense
There are different tips, In order for the unit to siphon the soap you need to use the tip that is for detergent. Its basically a tip that does not produce a high pressure it's more or less a soaker. Unit won't siphon under pressure. I hope this answer your question please rate the answer if it was helpful. Good Luck and have a great day. Jeff
Apr 04, 2010 | Karcher PSI Electric Pressure Washer
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
The motor works fine , no pressure out of hte hose, could it be the hose or pump, how do I trouble shoot. Also, how do I draw soap from a bottle to shoot out of the washer onto the house?
hose,
Jun 30, 2009 | Plumbing
Garden Logo
344 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
