Question about Garmin Astro 220 GPS
My dc30 collar has just frozen. The collar was working & then froze. The red led lights stayed on constantly until it ran out of charge and now when I try to recharge nothing happens?
  • 12,061 Answers
The unit has faulted, I have seen similar symptoms, before, especially with the two, LED's fading out, with battery, Your only option for repair is to return it to, "Garmin" for repair, I think, you have to contact then first and get an RMA Number, then, you forward it on, and they contact you with the details.
Posted on Apr 23, 2010
When charging the red light will cycle 7 seconds on then 2 seconds off and constantly repeat this cycle. However, the instructions state when charging the red might will stay on until fully charged. What...
Sounds like battery is no good There should be symbols on charger. Normally solid light charged. Blinking. Charging. Lights back and Foward battery. No Good won't accept charge
Mar 25, 2015 | LG HBS-700 Bluetooth Headset
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Dyson dc30 charging issue
Defective replacement battery - unable to charge/recharge.
Jul 11, 2017 | Vacuums
I want to make my dog a festive collar for Christmas? What are some good ideas?
You could start with some red ribbon. Add some bells that will jingle and some LED Christmas lights.
Dec 31, 2012 | Dogs
I own 15 garmin dc30 collars and when hunting they are spred out in no specific order over 3 astro 220 hand held units. I am having trouble receiving all of the collars. On one unit i may pick up for...
Hi, thanks for posting your Question..
At times you may experience Problems with a Garmin Astro DC30 Collar. I've heard And experienced reports of the following problems with Garmin DC 30 Collars
Before trying to do a Hard Reset for the Garmin Astro 220 DC30 Collar you should try and identify if it is the collar or the 220 Receiver. the easiest way you can do this is to check your Tracking System with another collar. If the second collar works fine then you can assume that you DC30 is not working as it should.
First i would Check all the basics, make sure the collar is charged.
I also would Delete and Re establish the Dog Collar in you system by going to the Dog List on the menu of the Astro 200, I would probably recommend Resetting the 220 receiver since it is much easier to reset that than the Collar.
Lastly, If these do not fix your problem you should try to "reset" the DC30 by
Removing the Back Plate (silver piece)
While Your looking at the connections for the two antennas, I would check to make sure there is nothing wrong with both the GPS antenna connection, and the VHF Antenna on the collar. Personally I carefully disconnect each and make sure they are both clean and free of Debris and Junk. (good Solid connection here will only help the performance of the collar) You can carefully use a brush or electronics contact cleaner for the VHF antenna (Screw mount) (See images below). I would not put anything into the SMP (square Antenna wire connector)
Removing the VHF Antenna on a DC30
Clean this before re-installing. Very Important to have a good Electrical connection3. Remove the Four Small Philips screws on the outside of the case to access the battery and electronics compartment. Very Carefully Disconnect the white battery connector from the board (see images below). Leave the battery Disconnected for about 15-20 minutes for a full reset, Reconnect it to the board.. (CAREFULLY) Here you Can see the battery Connector for the DC 30 Garmin
Different Angle of the connector for Dc30
As you re-assemble the Garmin DC30, Clean all seals and clean antenna connections.
Clean all seals and connections before re-assebling the Garmin DC30 collar
That is A Garmin DC30 Reset Instructions, and Many times when you are having Problems with Garmin DC30 collars this is the First step Garmin will ask you to do before sending them back.
Here is how to Mark a Location other than your location. For example You might want to mark the Tree before you get to it in case your dogs leave the tree. Most of the time If you are like myself You want to Scroll over and Hit the Mark Button, However that will just Mark Your current Location and not the location that your cursor is.
Here are the instructions To mark a location where your cursor is on your Astro 220.
Press map
Scroll the cursor over to the location you want to mark.
Press (ENTER) instead of pressing Mark.
If you press Mark it will mark your current location..
After you press enter.
It will either Select something that you've scrolled over and you should be able to save that as a Location, (Hint: you can change the name to what ever you want before you save it.)
Or if it doesn't select something it will say "no Map info at this point. Do You want to Mark a location here"
I know it's pretty confusing and counter intuitive, But that's how you can mark a location where you are not at.
If your Antenna's are not too OK,you can get a replacement from the below link:
http://garminastrodog.com/garmin-astro-dog-tracking-antenna-questions/
http://www.hdssupplies.com/garmin.html
Good luck and thanks for using fixya.
Jul 12, 2011 | Garmin Astro 220 GPS
Red light stays on
you will need to go into your menu under the system or display and turn off the LED indicator.
May 28, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Red LED stays on
Sounds like the rechargeable batteries are aged out, and no longer able to develop a full charge, and soon will be needing replacement.
A repair center might likely do it for you for a fee, but see "Self Repair" on site:
http://www.fixya.com/support/t961386-change_battery_in_norelco_5841xl_razor
Good Luck GB_C
May 06, 2008 | Norelco Reflex 5841 XL Electric Shaver
Charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Feb 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Frozen/won't turn on??!!!
Apologies if this answer is offensively obvious. Try putting a paperclip or equally small object into the little reset hole at the bottom of the player if you haven't done so already. Mine froze a couple of times and it always worked.
May 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Garmin Astro 220 GPS Logo
189 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
