Question about Patton PUH680-U Utility Heater
PUH680 Heater Just Bought - Questions
PUH680 - I lost the Manual. What's the difference between the #1 setting and the #2 setting? Is the light supposed to always stay on when the heater's plugged in? Am I supposed to unplug it when I'm not using it? Why doesn't the fan go on until I turn the dial all the way to the top? Does it heat before the fan goes on?
What do you think about them charging for assistance? I can't believe it.
  • jperwin Apr 26, 2010
    I was taken to a cite that asked for a credit card before it would respond to my question. After much effort,I eventually found a place to communicate comments. This was not the cite for answering questions. Try it.
  • Clark with Big Toast Dec 11, 2012
    MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
  • Patton Master
  • 43,501 Answers
The 1 setting is a 750watt setting and the 2 is a 1500watt or twice the heat...the light will always be on when you have power...the fan will go on if there is a call for heat and if the room if fairly warm it will be all the way to the top..does the company charge for assistance??? never heard of such a thing...
heatman101
Posted on Apr 23, 2010
  • reyer14810 Jan 24, 2011
    Thank you -- my question was much the same and this was helpful. However, I kind of remember some instructions for setting the thermostat at the desired level, but not really. Is there any way of obtaining replacement operating instructions?
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Heat 1 & 2
Typically 'Heat 1' means first stage heat and 'Heat 2' means second stage heat. Essentially a Lo and Hi setting. Just like a hair dryer.
Feb 26, 2014 | Patton PUH680-U Utility Heater
I HAVE A MODEL POH 682 IT HAS A TWO POSITION "ROCKER" TYPE SWITCH ON THE FRONT LABELED 1 & 2 . WHICH IS THE "HIGH" SETTING ? ...
It's an easy fix, so to speak. You Patton heater was recalled in December of last year. So now you are entitled to a new one.
Here's link that will give you more ino and a number to call:
http://thestir.cafemom.com/home_garden/113974/huge_walmart_heater_recall_over
Feb 09, 2011 | Patton PUH680-U Utility Heater
Which is the higher setting #1 or #2
Sorry to read about your problem, I hope this helps you out.
2 is
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Patton Electric Patton PUH680-U Electric...
CAN THIS HEATER CAUSE AFIRE AND IS THIS HEATER ON RECALL PATTON PUH680-U
I do not know if this heater is on any product recall but we have used patton heaters for years and pretty much have had good luck with them. However there is a fire hazard present if you set or store combustibles to close to the front.Tip over switches don't always work and I would never recommend using a heater of this type in a unsupervised area.I hope this is of some help to you. Thank you and happy holidays.
Dec 20, 2010 | Patton PUH680-U Utility Heater
My Spedometer and Tacometer have stopped functioning.
Sounds like a ground problem.Questions:
1) Do you have electrical or electronic troubleshooting skills and tools?
2) Can you read schematics?
3) Are you comfortable removing instrument cluster and working behind dashboard if necessary?
If all the above are true, then I might be able to hook you up with the help you need. However, it might be too much to post here.
May 24, 2010 | 1994 Volkswagen Jetta
Heater coils on a aloha utility heater lights up
It is typical for the elements to glow. The glowing is caused from the high amount of electrical flow through the coils. It is the same principal of how some light bulbs work.
Feb 17, 2009 | Patton PUH680-U Utility Heater
Patton PUH680-U Utility Heater Logo
909 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
