Question about Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
Problem Installing an External Hard Disk USB2.0
Hello
I got this External Hard Disk WD 500GB , USB2.0
i tried to connect it to my PC ( using Windows XP ) and when the windows dedcts it , it installed as " Prining support " or some times says " MassStorage Device" ... and i cant see the External on " My comp.."
i thought i unable the USB from the BIOS.. so i enter the BIOS .. and i noticed that the External shows in the boot options..
and i tried to use it on other comp.. so i tried it on my Laptop and it was working perfectly... i pluged it and withn 15 secs it was automaticly installed.. and working and shown in " My comp"
I want to use it on my Desktop.. i got this External like for 3 weeks
i mailed the WD support and the didnt even reply on my or any thing..
The external working fine as it seems to.. But how can i fix this problem to make it works on my Desktop as well ?...
Glad to get any ideas that may help..
Best regards, evo
  • eVoTech Mar 25, 2008
    There was no any drivers to install. i went to the WD website.. there wasnt any drivers for it.. i should installs automaticly..
    i tried some thing .. i used a USB HUB... and it was working but very slow...
    Does that means my USB on the motherboard are Dammged ?
    There is any way to install any USB ports that connects to the MOBO ?
    Thanks for you're support IBG42008
I bought the king's tone usb of 2 gb and i set passward in 1 gb and make 1 gb free space but i mistakely deleted the folder to inter in the 1 gb where i had set the passward so my 1 gb space is lost so how could i get bak to it to....please tell me to solve this problem
Posted on Sep 12, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
No need to install the drivers, the usb drivers will get automatically installed.
And usb devices are plug & play.
So dont worry about that.
Or
i.Close all explorer windows
ii. open task manager and kill the "explorer" program
iii. in task manager select "File--New Task(Run)-- explorer
Or
Just try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer,scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Or
1. Connect the USB enclosure to the computer and turn on the computer.
2. Go to Control Panel - Administrative Tools - Computer Management. In the Computer Management window click on Disk Management.
3. In the Disk Management window you should see 2 hard drives. Disk 0 – that’s your primary hard drive and Disk 1 – that’s the hard drive in the USB enclosure.
For the Disk1 you’ll see the HDD size inside the bar and also it should say Unalocated. It means that the new hard drive is not partitioned and formatted.
4. Right click on the unallocated space and click on new partition entry, the wizard for creating a new partition on the hard drive will appear.
In most cases you should chose: Primary partition, partition size would already in there (entire drive), assign any free letter or leave it default, file system NTFS (default), check the Perform a quick format (faster) box, NEXT and FINISH.
It might take some time. You’ll see that the LED on the USB enclosure (if you have any) will start flashing.
5. After it’s done, you should see that Disk1 says: New Volume, HDD size, and Healthy.
Now, if you go to My Computer you should see the second hard drive and you can use it as a regular drive.
If so, it can hide drive letters. Look up TWEAKUI and use that to see if drive letters are hidden.
You can download it from here
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
Good Luck.
Live, Love, Laugh.
Posted on May 10, 2008
    Genius:
  • 3,587 Answers
Did yo install the drivers on the new machine, First?
Posted on Mar 23, 2008
  • Patrick Michaels
    Patrick Michaels Mar 25, 2008
    nope..usb ports are built in, unless you can run them from the interface connections on the board..takes some serious jumper shifting, and only some boards support it.
    thankya for using fixya
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
Hello I just connected an external SONY memory to my computer there were many shortcuts which the owner said he does not need them and can be deleted. since after two days I connect my external WD 500GB...
first thing; do a Windows "System Restore" Immediately. When doing "System restore" choose a "Restore Point" (date) just prior to the date you installed the WD 500GB.
Next, before connecting the external hard disk again,go to the Western Digital website and download all of the drivers and software for the hard disk,and then install it using those drivers and software.
Mar 28, 2011 | Computers & Internet
When i plug in my WD External Hard Drive 500gb it show to be un readable in disk managen ment and gives no options to fix it
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 09, 2010 | Western Digital 500GB My Book Pro-External...
My wd smartware has suddenly stopped working. it shows not working checking for solutions... and then fades off. connecting my wd passport essential 500gb...i can unlock the hard drive to see the...
* the USB cable
* the power-adapter
Nov 21, 2010 | Western Digital My Passport Essential...
My hard disk is western digital 500GB sata blue caviar 16MB 7200RPM .... it stopped working toady with no reason, it was working fine yesterday night, when i wake up today i found its not working any more...
> stopped working toady (froggy? today?)
It "died" -- either the electronic circuit-board "under" the "spinning" part of the disk-drive has short-circuited, or the motor that spins the recording surfaces has quit.
You've tried it on another computer -- so you've done all that you can.
Any 500GB disk-drive is likely to still be under the W.D. warranty.
Open the enclosure, and get the model-number and serial-number from the label on the disk-drive.
Then, access the W.D. web-site, and click "check warranty status", and enter that information.
If the warranty is valid, W.D. will replace the device, at minimal cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program -- purchase a new W.D. device from the W.D. web-site, and you qualify for a good discount on your purchase.
Or, remove the disk-drive from the enclosure, buy a replacement, compatible, disk-drive, and "transplant" it into the enclosure, to create a working external storage device.
Nov 02, 2010 | Western Digital 500GB My Book World...
My Western Digital 500GB EDD has been making Clicking noise
Here are some options to try: - Purchase an alternate enclosure for your hard disk enclosure in case the circuit board in the WD case has gone bad. - Try accessing the drive via MS DOS window and use CHKDSK command to repair the drive (if you can get it to be recognized). - Try connecting the drive to an alternate PC or even a Mac to see if the drive can be recognized (perform disk repair if recognized).
Feb 10, 2010 | Western Digital My Book Essential Edition...
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
PC does not detect my External HD
It won't work because Windows XP is no longer being supported from Microsoft.
Jun 11, 2017 | Western Digital My Book Premium ES...
Western Digital My Book  Premium ES Edition  WDG1SU5000 500 GB USB 2.0 Hard Drive Logo
364 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
