Question about Garden
When I pull it kicks back and wont start - Garden
  • 23 Answers
Have you ran over something recently ,could be the shear pin at the crank has sheared which would throw it out of time.
Posted on Apr 23, 2010
I have a honda gx 390 that kicks back when i pull the rope to start
The ignition timing may be too advanced . Some times if the pull start rope is not pulled hard enough it will kick back, The ignition fires just before top dead center , if not pulled hard enough it will kick back.
Oct 15, 2014 | Garden
Kawazaki kdx 125 wont start
KICK HARDER TRY PULL STARTING IT..IN SECOND GEAR..DOES IT HAVE ENOUGH COMPRESSION TO START?IT SHOULD START PULLING IT...START OFF WITH NO THROTTLE THAN IF NOT STARTING CRACK THE THROTTLE SO LIGHTLY AND SHE SHOULD FIRE OFF WHILE IN GEAR BEING PULLED OF COURSE BE CARE FUL NOT TO RUN INTO. WHO EVERS PULLING YOU..USE A LONG TOW ROPE..IF YOUR NOT A SEASONDED RIDER AND KNOW YOUR BIKE VERY WELL I WOULD NOT ATTEMPT THE PULL START...IF NOT CHECK YOUR COMPRESSION AND TIMING..MAJOR VACUUM LEAK MAYBE AT BASE GASKET..IS ENGINE SUCKING TO MUCH AIR? GOOD LUCK..
Mar 02, 2013 | kawasaki KDX 125 Motorcycles
2005 malibu sometimes wont kick over when trying to start
sounds like a security issue or possibly a bad bcm, may be hard to diagnose due to it being intermittant, have you pulled codes
Jan 17, 2013 | 2005 Chevrolet Malibu Sedan
Hey guys just bought a 426 was running gud. started 2nd kick almost every time.they guy i got it off said never been serviced in long time so i changed oil pug and filter..the bike was perfect put it back...
did the guy give you the starting method. if not you have flooded the plug and it will only start if you replace the plug or dry it out.
method. dont touch the throttle. pull decom lever and kick over 10 times.
release lever get topwith kick start. pull decom lever slightly to allow kick start to drop 1 notch. release lever and let kick start back up and kick hard.
repeat should start second go.
Feb 14, 2012 | 2002 Yamaha YZ 426 F
Engine cranks and is getting spark but wont start it kicked back hard enough to break a starter mounting bolt i replaced the crank sensor and starter maount bolt it cranks but still kicks back and will not...
The timing is out . you can check this by getting #1 to TDC, pull the cap off and see where the rotor is pointing. It should be pointing to the # 1 cylinder. Gas engine
Feb 08, 2011 | 1998 Chevrolet K2500
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
Kick Start wont engage
check pawl spring on kickstart lever.
Apr 18, 2010 | 2004 Yamaha YZ 250 F
Kickstart wont move
Make sure it is in nuetral before trying to kick or the brake will keep engine from spinning. Otherwise have some friends push start you that will let you know if engine is good.
Jul 25, 2009 | 1979 Honda CBX
Wont start by kick start but will by pull start
sounds like your idle jet is clogged, remove your carb and clean idle jet cause it won't idle or kick start without it...good luck to you friend...Tim
Jun 05, 2009 | 2003 kawasaki KX 125
Starting my Mojave 250
check comprsion. check valve clearance.
Apr 26, 2009 | kawasaki Full Suspension Mountain Bike Men
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
