Question about Epson Stylus Photo 950 InkJet Printer
Blocked ink jet nozzles
How to unblock ink jet nozzles on Epson Photo 950
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Posted on Mar 12, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
pidatoo
  • 118 Answers
SOURCE: i can t find a driver epson stylus photo 950 for mac os x 10.4.11
find the manurfactures website they usualy have the DRIVERS to install for free on their site, from there you can download it.
Posted on Jul 23, 2009
  • 133 Answers
SOURCE: WINDOWS 7 DRIVER
Some have had success here:
http://www.bioticaindia.com/stylus-photo-825.html
Posted on Apr 21, 2010
The black ink will not print on my Epson Stylus SX600FW printer. Th eprinter was left for a few weeks without black ink. Has the needle heads dried up and become clogged? How can I fix this problem?
I have an Epson sx600fw which has had a problem printing with black ink. I spent alot of money trying genuine and cheap inks as official advice is to replace with a genuine epson cartridge and clean up to 6 times before seeking further help. Tried this to no avail. By accident I found that if you set the paper type to glossy or photo then miraculously the black will work but in this setting it is slow. Epson replace the printer under warranty but I have just received a new one and it has exactly the same problem. I am slightly reluctant to buy another set of genuine inks to waste through 6 cleaning cycles as they are over £35 so am not sure what to do but I guess I will approach Epson again.
Sep 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Inconsistent color, nozzles clean same ink cartridge same paper
Problem with ink continuity. Ink at head spray out, but ink at tank not flow to head. Print block color for each color. Is it perfect? Do nozzle check, head cleaning, wait for 30 minutes. Check again.
Aug 16, 2009 | Epson Stylus Photo 915 InkJet Printer
Epson 1400 Printing Orange colors Green
The problem can be two fold. Wrong cartridges, or blocked/damaged inkjet openings. Return it to the seller under warranty if its brand new. If it was fitted with non epson cartridges your warranty may be in question.
But I could almost guarantee the black qand the blue cartridges are faulty or their feed jets are
Jun 20, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson stylus r230 printer
the jet is clogged... set the self clean mode on if this does not fix it try another cartridge. if you have been using refilled, recycled cartridges this may have damaged the jets. common fault that recyclers know about but dont give a toss. ink should be filtered 9 times before being injected into cartridge most recyled are filtered once. this causes jets to become blocked, overheat and actually melt
Jun 20, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Only the yellow and black prints even after change the ink to new.
Sounds as if the nozzles are blocked, If the Epson cleaning tool does not get results. the only cure is to manualy remove the dried up ink. Since some disassembly is probably needed and the nozzles are easily damaged, it is a method of last resort. Current prices suggest that it would be better to replace it with a T20 printer.
Prevention, always power off using the printers on off button, as this ensures that the printer heads are parked properly. This prevents drying out, the cause of your problem. It also helps to use the printer every month or so, Not a monster session once or twice a year, Ink jets hate this.
Feb 27, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson stylus photo 950 printer flashing lights
Ink Overflow -
Solution:
Sep 28, 2008 | Epson Stylus Photo 950 InkJet Printer
Open Questions:
See all Epson Stylus Photo 950 InkJet Printer Questions
Epson Stylus Photo 950 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
