Question about kawasaki Full Suspension Mountain Bike Men
I have a 1988 Rx 1000 Kawasaki, after filling up the tank the bike started to splutter at low revs, i took her to a bike mech and he found atleast 8 lts of fuel in the sump as well as the exhaust soaked with fuel. he could not give any explanation and the bike was road tested -ok. two days later I have again just filled her up and noticed as I started her this morning - fuel was coming from the bottom seals, I looked in the tank and most of the fuel has gone, obviously the same has happened again, any ideas,regards.
SOURCE: a reg kawasaki gt 550
i would say you need to have your coil checked.
Posted on Nov 12, 2008
hermit58
  • 33 Answers
SOURCE: Nearside carb problem on kawasaki zzr1100
Clean your carbs! Your floats might be sticking open a bit. Plus, all Kawasakis have a simple spring-actuated check valve in the fuel valve. This way, you can disconnect the fuel line without having to block the flow. Fuel could be leaking through the check valve. Your problem most liklely identifies dirty gasoline. Clean out your tank, your carbs, and change your fuel filter.
Posted on Apr 08, 2009
  • 84 Answers
SOURCE: I have a kawasaki zzr600e that produces a
white and milky is water in your oil, its everywhere because its overflowing. its 100% a major problem and the longer the bike runs the more likely itll need a new engine
Posted on Oct 30, 2009
  • 3567 Answers
SOURCE: I have a Kawasaki ZZR 250. Just bought it. Started
One or both of the floats are stuck open giving the carbs fuel constantly. The extra fuel runs into the intake, fills the cylinder, gets past the piston rings and then fills the gearbox and overflows onto the floor. Pull the carbs and clean them. Some trash, ( such as rust from the tank ), is not letting the float needle to seat. Be sure to sync and balance the carbs after re-installing. Also, turn off the gas at the tank when you are not riding. If you already are doing this, the petcock must not be shutting off properly and needs to be replaced. Please rate my answer. Thanks.
Posted on Dec 17, 2009
  • 474 Answers
SOURCE: Kawasaki ZZR 250. Engine hydrauliced after fuel
sounds like you blew a set of piston rings. instead of building compression in the cylinder its pressurizing your crank case forceing the oil out the breather into your air box
Posted on Dec 19, 2009
1987 Kawasaki GPZ 1000 RXv will not rev past 3000 RPM
Hi, Mick and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor damaged, contaminated, sticky float, plugged jets.
13. Multiple carburetors out of sync.
14. Fuel filter clogged.
15. Old or contaminated fuel.
16. Fuel tank vent system plugged or carb vent line closed off.
17. Gas cap diaphragm valve faulty.
18. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
19. Carburetor controls misadjusted.
20. Incorrect valve timing.
21. Valve springs floating, weak, or broken.
22. Damaged intake or exhaust valve.
23. Incompatible performance parts.
24. Control module may be in "LIMP" mode
25. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
wont go over 3000rpm
HELP 08 1k won rev past 3000 rpm
Kawasaki GPZ900R ZX900 Workshop Service Repair Manual 1984 1990 1 Download... $17
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Jun 08, 2017 | 1987 kawasaki GPz 1000 RX
If my bikes karborators vlude how do I fix it
Hey Chris, Could be a stuck float in one of the carb. bowls. Don
Jan 10, 2015 | 1988 kawasaki GPz 1000 RX
Why does my DT125 splutter at hight revs
Sounds like either the bike is starving for gas at higher RPM's, or you're hitting the rev limiter.
Jun 15, 2012 | Yamaha DT 125 R Motorcycles
Kawasaki gtr 1000 1988
Check the battery voltage sounds like a bad battery also check the clutch switch
Feb 22, 2012 | 1988 kawasaki GTR 1000
HI THIS IS VIS. MY KAWASAKI GPZ1000RX RIDES FINE UNTIL I'VE DONE +- 40KM THEN SHE JURKS ALOT
this could be a blocked air vent on the fule tank if she starts doing it again on you undo the fule tank cap asap if its hard to open or you here a sucking sound that would be air rushing into the tank as its got a vacuum in it so the fule cant get sucked out any more
Jan 13, 2010 | 1988 kawasaki GPz 1000 RX
I have a Kawasaki ZZR 250. Just bought it. Started well. After a drive Inparked on a steep driveway. When trying to start rev's would only get to 1000 even with full throttle. After 10 minutes tried it...
Dec 17, 2009 | 1991 kawasaki ZZR 250
Rx 100 reverse start
Make a couple of calls to different Kawasaki dealers in your area. Ask what direction the flywheel is supposed to turn when the engine is running. Chances are the mechanic is seeing a directional arrow on the odd-lot flywheel when the correct flywheel has the arrow going the other direction. Put the bike on the centerstand. Start the engine and put it in first gear. The sprocket should be turning counter clockwise.
May 20, 2009 | 1986 kawasaki GPz 1000 RX
Kawasaki gpz 1000 rx 1987 model
Running well at high revs would indicate that all the fuel and air it needs are getting to the engine and you also have a good spark. Probably no problem with air and fuel filter ( if fitted) or sparkplugs.
Running hot, and bad idling are signs of a lean air fuel mixture. The engine is probably not getting enough fuel at low revs.
This could be caused by an air leak between the carburettors and the engine. Check that the vacuum line to the fuel tap is properly secured at both ends. It is behind the fuel line at the tap.
Get a a short length of hollow plastic tube and use it like a stethascope - put one end to your ear and move the other end around your carburettor mounts with your engine revs as low as you can get, and listen for any sucking noises that would indicate a leak. Look for cracks in the rubber inlets.
The other possibility is that there is an internal blockage in the idling jets or idling fuel circuit. This is where dirt tends to lodge because the jet dimensions and passageways are very fine - The high speed jets are much bigger and dirt often just passes straight through.
Try a little bit of choke while the engine is warm to see if you get a stronger low speed response. If so that would point to an internal blockage.
Jan 24, 2009 | 1987 kawasaki GPz 1000 RX
Paint protection
the 3M protective film works really well, I have it on the nose of my GTI. It will add some sheen, but I highly reccomend it
Nov 20, 2008 | 1988 kawasaki GPz 1000 RX
kawasaki Full Suspension Mountain Bike Men Logo
32 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
