Question about HP iPAQ HX2750 Pocket PC
My ipaq 2750 has frozen on ProtectTools screen. I have activesync installed but it wont even recognise the cradle device
    President:
  • 1,118 Answers
There's a chapter called 'Resetting your HP iPAQ' on your device's User Manual. Firstly, perform a soft reset. If it doesn't solve your problems, jump to the hard reset procedure. If it still doesn't do the job, then, perform the clean reset procedure.
Just in case you happen to miss its manual, you can download it from this location.
Hope you are able to sort your problems out.
Cheers! Carlos
Posted on Apr 23, 2010
USB connection to PC problems
You must have ActiveSync installed and running on your WinXP PC, for a WM device to be allowed to synchronize its data. Just in case your PC happens to be missing it, you can download it from this location.
Hope it works for you.
Cheers! Carlos
May 09, 2010 | HP iPAQ hx2190 Pocket PC
HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
Mar 28, 2008 | Computers & Internet
HPiPAQrx5915 wont active sync with pc or laptop by usb or bltooth
What version of ActiveSync are you using? Open ActiveSync on the PC, then open "About ActiveSync" under the "Help" menu - it should be version 4.5. If not, download version 4.5 from Microsoft as a first attempt to fix the problem. If you are using 4.5, try uninstalling/reinstalling again but make sure you do a soft reset (push the pin on the top of the device) before you connect the Ipaq. If this doesn't work let me know and we'll try some other things.
Mar 02, 2009 | HP iPAQ rx5915
IPAQ H5555 connection problems
Hi, This could be due to a few issues, try these soloutions in order below: 1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again. 2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again. 3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case: a) unplug the USB cradle b) uninstall active sync c)Click start then click control pannel then click system. Then click on the hardware tab. Look for the device under USB, right click on the device and then select uninstall. d) restart the laptop e) Install active sync f) ONLY after active sync has installed you can now plug the cradle back into the usb socket. g) Now connect the ipaq, it should now detect it.
Aug 09, 2007 | HP iPAQ H5555 Pocket PC
Syncronizing
All you need is Activesync which can be obtained from this link.. http://www.microsoft.com/windowsmobile/downloads/activesync38.mspx and you need OUTLOOK installed and configured. It's important not to cradle the Ipaq until you are told to from Activesync. Try the following before you try to connect again... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
Cannot copy large files to my SD card
Yes , the Activesync connection is not reliable for large files. You really would be best to get a USB card reader, also it would be MUCH, MUCH faster.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
IPAQ 1715 not recognized
All you should need is Activesync. Try the following... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 08, 2005 | HP iPAQ RZ1715 Pocket PC
Please help! Cannot sync....
You need to install Activesync onto your PC. Activesync comes on the CD that came with your Ipaq , or the latest version can be downloaded from here... http://www.microsoft.com/downloads/details.aspx?FamilyID=2eb5bd80-d52c-45 60-ae11-da92f2b229fa&DisplayLang=en Then from your PC (not your IPAQ), open Activesync, click on File, Get Connected and do NOT cradle the IPAQ until it tells you to. The Activesync on the IPAQ is for wireless syncs, which cannot be done until youu establish a partnership with this first wired sync. You will need a wireless network to do a wireless sync.
Sep 07, 2005 | HP iPAQ RX3700 Pocket PC
Sync problem
Try downloading the newer version of microsoft Activesync from Microsoft download center.
get it here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9e641c34-6f7f-404d-a04b-dc09f8141141&DisplayLang=en
This ought to solve connectivity problems.
Happy fixing!
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ HX2750 Pocket PC Logo
157 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
