Question about Samsung ML 4551NDR - printer - B/W - laser
I am looking for spare parts of samsung 4551 printer cartridge...where do i get it
Toner smudges
no exact idea which exact part - However had a similar problem in my laser printer. I used a can of compressed air with the printer outside the building and sprayed the air on everything that the paper would come into contact with inside the printer with the toner cartridge removed out of the printer. And problem was resolved. I suspected the paper rollers . you can get a can of compressed air from electronic spare part type stores like Jaycar
Jun 20, 2017 | Samsung ML-2850 Series
Canon printer model MP258, error number B200. pls kindly assist my printer problem. what do i need to fix this error from my printer...? thanks!
You've experienced it over the P10 error on the Canon MP258 printer, to repair the damage we must examine several parts spare parts inside the printer. Spare PartsPrinter Parts Canon MP258 which can cause Error P10, is
1. PG810 or CL811 Cartridge
2.
Unit complete with cable Cariage his head.
3. Logic Board.
above error solved by replacing one or more spare parts on top. To fix it we canbegin to examine the parts of the easiest parts first, beginning from the secondfruit of its cartridges, if both its cartridges is fine proceed to the units and wiredcariage his head , last if still error occurs P10 possibility of damage is at the logicboard. may be useful ...
Jun 12, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
We have a thin down the middle of the page
2 words. Toner Cartridge.
90% of all print quality issues on laser based printers such as this are caused by a defect in the toner cartridge. Swap the cartridge and fix this problem. If you dont have a spare try removing the toner cartridge and looking at the drum cylinder in the cartridge. If you see any kind of similar black line on the drum you will have proof that it is the cartridge. The ONLY other possible cause would be the fuser unit. But my money is on the toner cartridge.
Good Luck and Thank You for using Fixya.
May 12, 2010 | Samsung ML 1430 Laser Printer
It looks like ink blotting down the right side of page and a dark spotty shadow or something , what's up with that
Most of the time this is going to be coming from the toner cartridge. If you have a spare, even an empty one, replace the toner cartridge and see if the spotting goes away. If you do not have a spare then remove the toner cartridge, turn it over and slide open the "gate" that covers the drum. The drum should be clean and for the most part shiny with no scratches or wear. If the toner is defective you may be able to see the same line or spots on the drum surface that you are seeing on your prints. This will provide proof that the source of the spots is the cartridge.
If changing the cartridge does not resolve the problem then the only other possibility would be the fuser film. These do go bad over time but would require a service technician to replace and thus a new laser printer would be cheaper to buy than replacing the fusing unit in your current machine. Assuming it is an HP 1100 similar to what is pictured in your post.
Jan 07, 2010 | HP LaserJet 1100 Printer
The printer is printing dark vertical line on the
90% or more of the time on this printer dark lines are coming from your toner/drum cartridge. You can verify this by changing cartridges if you have a spare. If you don't then remove the cartridge and look at the colored cylinder in the cartridge and see if the same "lines" are on the cylinder that are on your prints. This will tell you for sure that the cartridge is bad.
Dec 13, 2009 | Samsung ML2250 Laser Printer
Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Oct 26, 2009 | Samsung ML 2010 Laser Printer
How to remove the handle of a monticello 4551 moen faucet. I need to access the cartridge. After screwing the brass stem out, does the chrome ell shaped cap rotate to unscrew or is there a set screw I...
grab bottom of handle,(the fat part of handle closes to faucet body) and grip hard and turn counter clockwise to get to cartridge. dont use channel locks pliers or you risk damage to finish. can be done by hand and very tight grip
Jun 23, 2009 | Moen 4551___ Monticello Popular Two Handle...
SCRATCHED SCREEN
You need to have the display panel replaced, that is an expensive part.
Not much I can do from here, the panel must be ordered, as this parts are not normally on stock.
The best thing to do is calling Samsung to get part price.
SAMSUNG United Kingdom - Main
Samsung Europe
SAMSUNG United States - Main
SAMSUNG Australia - Main
Samsung Spares - Genuine Spares, Spare Parts & Accessories
Apr 28, 2009 | Samsung HC-P4752W 47" Rear Projection...
Invalid transfer belt error on Samaung CLP 600N
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
Mar 23, 2009 | Samsung CLP-600N Laser Printer
Samsung ML 4551NDR - printer - B/W - laser Logo
54 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
