Question about Samsung LN-S4051D 40 in. LCD Television
When you turn tv on it keeps clicking on and off, will turn on eventually after about 5 minutes
    Scholar:
  • 56 Answers
To fix PS Board parts.
Faulty parts on PS board , bad press for Samsung.
When checking the capacitors, If they are slightly rounded on the top where the X is, the cap is defective.
Because the Samsung LNS4051D would not turn on and the power
LED would blink 4 times and the relay would click and this
would repeat again and again. I replaced power supply board
parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors,
three had their tops bulged up slightly that I missed on
initial visual inspection. After seeing the reports of
problems with these caps on
http://www.fixya.com/support/t1336881-will_not_turn_or_off ,
I replaced them with Radio Shack part 272-1032, 1000 uf, 35v.
They are slightly bigger, but fit OK. TV is working fine now.
Cost was 4 x $1.59 = $6.36 plus the time. I saved between
$100 to 300 in the process of either replacing the board or
getting the unit serviced. If you are not comfortable
replacing components which means using a soldering iron, you
can replace the power circuit board, available from
www.Samsung.PartStore.com.
Some UTube showing the problem and fix -
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related
http://www.youtube.com/watch?v=Mm51C_RDIZE&feature=related
http://www.youtube.com/watch?v=BNHHrgX_6cs&NR=1
Posted on May 27, 2010
    Problem Solver:
  • 10 Answers
Your power supply has blown a capacitor. you will need to replace the faulty capacitor/s
Posted on Apr 23, 2010
3 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: My Samsung T5271F is taking
You have failing capacitors on the power supply board. This is a very common issue with these and others. If you know how to test capacitors and solder its not that tough to repair. Or you can just replace the power supply board which is part number BN44-00184A and runs around $100. You can purchase the board at many places on line. Just do a search in Google with the part number,,,,Good luck
Posted on Sep 18, 2010
  • 88 Answers
SOURCE: My tv when you plug
not sure but call sears they charge $99 to come out and free estimate
Posted on Dec 19, 2010
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
Tv clicks when trying to plug it in and won't turn on
begins working for alomentacion source that can be damaged or filteos the same regulatory
Jan 05, 2010 | Apex Digital AT2002S 20" TV
Tv keeps turning itself off and needs to be off for 5 minutes or more before allowing to be turned back on. Once on, there is a audible click and hum for about 2 minutes.
There is likely an overheated capacitor. Most likely in the power supply. It is actually extremely common now days, especially in newer electronics.
First try dusting out inside of tv and all the venting
Aug 27, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Samsung LNT-4665F takes several minutes to turn on
This could be the power supply problem, or the main board. You need technician to fine out what is going on.
Aug 16, 2009 | Samsung LN-T3253H 32 in. LCD Television
Wont turn on
Take the back off of the TV and look at the power supply board (middle of the set). One or more electrolitic capacitors will have the tops swelled up. Replace them with the same value parts and you will be OK.
May 17, 2009 | Philips 50MF231D 50 in. Plasma Television
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
Tv Powers up and immediately back off
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Aug 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Samsung LN-S4051D 40 in. LCD Television Logo
164 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
