Question about Garden
Starts up but will not run under load - Garden
  • njbtheraven Apr 24, 2010
    Very Helpful, Thanx
  • 821 Answers
HELLO,KINDLY GET A new spark plug and also clean your battery terminals and you will have your riding mowers working perfectly.
take ccare.
Posted on Apr 23, 2010
I have a Troy Bilt trimmer model TB675EC...4 cycle engine. Problem that has arisen is that it dies at high speed and under load. Starts up and runs at idle well.
Fuel starved, carb should have an idle adjustment which sounds like it is fine. Look for the second adjustment
Jul 17, 2017 | Troy Garden
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Craftsman mower runs rough sometimes when engine has load on it.
adjust the mixture screw on the carburetor while under a load.
Apr 20, 2013 | Garden
I have 1991 f150 302 . under a load starts to
renew plugs and high tension leads[wires]
Jul 11, 2010 | 1991 Ford F150
Starts good runs good on idol, but under load misses
Is it a lp,gas are diesel?...If lp are gas check timing and point are in some cases the flapper in the carberator.If Diesel it possible the flex ring is coming apart in the injection pump and stoping up the return lines at the injectors retarding the timing advance in the injector pump..very common in the 3020 4010 4020 4320 and 5020 John Deere ag tractors...
May 16, 2010 | John Deere 3010,3020 Tractor Basic...
CRF 250 R starts & runs fine when cool, not when hot.
it sound like electrical brake down under load check coil
Jan 11, 2010 | 2005 Honda CRF 250 X
Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Jul 18, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
