Tapping function is not working (acer aspire one)
My acer aspire one touchpad, tapping function is no working, others function is ok
  • 50 Answers
Install touchpad driver.
Posted on Apr 23, 2010
Download driver here worked for me!
[code]http://www.small-laptops.com/10-inch-acer-aspire-one-windows-7-page-2/[/code]
Posted on Dec 14, 2010
The up and down scroll of the touchpad on my acer aspire 5630 with windows vista is not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 29, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 5735 touchpad not working properly doesn't zoom
You can try updating the software for the touch pad but the most likely problem is you have a bad touch pad. Touch pads don't necessarily go all at once. You lose some functionality. In your case, it would appear you are able to to point and move the cursor. You didn't mention, does the touchpad respond when you tap it to hit ENTER instead of hitting the ENTER key itself. This is 1 area that will commonly lose function over time as well.
Nov 10, 2011 | Acer Aspire 5735 Notebook
My acer aspire 5551-2036 synaptics touch pad tapping function stop working. pls help. thanks.
check your touchpad settings to enable and adjust the tapping settings. if this does not work, try to reinstall your touchpad driver by downloading the latest one from the acer support web site.
Apr 21, 2011 | Acer Aspire 5100 Notebook
How do I disable my tap function on the touchpad?
Start by navigating to the 'Control Panel': --> Open the 'Start Menu' --> Click 'Control Panel'
Then open your 'Mouse Properties': --> Click 'Mouse' (You may have to click 'Switch to Classic View' before this option is enabled.)
To disable the tap-to-click function: Click the 'Device Settings' tab at the top of the 'Mouse Properties' screen, and then click the 'Settings' button. --> Select 'Tapping' --> Remove the check from the box labeled 'Enable Tapping'
Press 'OK' to save your settings.
Jan 30, 2011 | Acer Aspire One PC Notebook
My touchpad will not respond when I tap it anymore. I have to use the left button. I used to be able to tap or double tap the touchpad and it would act like the left mouse button. All of a sudden it...
On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one touchpad mouse does not work. USB mouse works. Also FN F5 stopped working
Aspire D250.....
Hold down function key fn (lower left on keyboard) and tap F7 key once..
May 02, 2009 | Acer Aspire One PC Notebook
Acer aspire 5620 touchpad problems
Go to acer website and look for support/then driver download/select your model/and download/do RUN instead of SAVE
Aug 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Touch pad not working correctly
If u are having Synaptics Driver....then
check that Tapping is enabled...
follow steps to know that:
Open Control Panel..
Now Open Mouse
Now click on tab "Device Settings"
then Click on "Settings"
a new window popups
Click on "Tapping" which is listed on the corner of the window
Now after clicking on it...on the right...check that there is "Tapping Enabled or not"
if not...click on that White box...
and Apply
then ok
Done :)
_________________________________________________________________________________
Sorry 4 my english!
Oct 09, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
607 people viewed this question
David Payne
David Payne
