I had windows7 in my system.. i want to format it... How i can format it in the command prompt
  • Mark Joseph Morales May 11, 2010
    What will you format? drive C: or drive d:?
  • 23 Answers
You cannot format a hard drive through windows comand prompt Try booting you PC fron the windows disk and follow the aesy steps it guieds you threw.
Posted on Apr 23, 2010
File system error 65535
I would suggest you to run a SFC scan on the computer.
1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.The access the drive by typing command for example - if you are facing trouble in C drive type C:
2. Type the following command, and then press ENTER:
sfc /scannow
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
http://support.microsoft.com/kb/929833
Also try running a Check disk on the computer.
Check a drive for errors
http://windows.microsoft.com/en-us/windows7/Check-a-drive-for-errors
Hope this information is helpful. Please let us know if you require further help.
Regards
Sep 10, 2012 | Western Digital Elements powered by WD 320...
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Tip
How to Install windows 7 by using usb flash drive, pen driver or usb harddisk.
Friends i have seen thousand of laptop cd/dvd rom stops working very soon. then the quesion is how you do intall your os if it was corrupted.
follow my tip and install windows7 or vista in very simple way.
a) first insert your usb flash drive or hdd in usb port
b) then open commandprompt from accessories with rightclick run as administrator
c) you must know what is drive letter of your usb flash drive.
d) type DISKPART in command prompt and press enter
e) then type LISTDISK in command prompt
f) Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
g) Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
h) Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
i) Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
J) Copy your Windows 7/Vista DVD contents to the USB flash drive.
Eject the usb drive and select first boot device usb drive or usb hdd in motherboards bios.
enjoy... and please rate this trick.
on May 11, 2010 | Computers & Internet
How do I get to a C: prompt
You can find a "terminal" in the "accesories" menu, that's the closest to a command prompt you'll find in Ubuntu.
Nov 18, 2011 | Canonical Ltd. Ubuntu
I am trying to format sony vaio pcg-c1mrx in command prompt but i dont know what the command to enter. please help me how to do this. thanks!
try these
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B ' /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B ' /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B ' /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B ' /S] [/C]
here are the explanations
/V[:label]
Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C
Tests clusters that are currently marked "bad."
hope this helps.let me know
Dec 31, 2010 | Sony VAIO PCG-C1MRX PC Notebook
I am trying to update my back up but I get a message the disc is full (although it does not appear to be when I look at its porperties). I am instructed to delete and backup the files again and when I try...
I thing your file system is FAT32.fat 32 can only store file size of maximum of 4GB.change file system to NTFS.
To convert a volume to NTFS from the command prompt
  1. Open Command Prompt. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. In the command prompt window, type: convert drive_letter: /fs:ntfs
For example, typing convert X: /fs:ntfs would format drive X: with the ntfs format.
Aug 29, 2010 | LaCie (300770) 250 GB Hard Drive
How can I format my newly bought Seagate 250 GB External Portable Drive into FAT32 system. Are most dvd players now with usb support for divx cannot access external drives that are in NTFS format such as...
You can specify the format type on the option page for format before you press the format button when displaying the drives in "My Computer"
Additionally, you can CONVERT an existing FAT or FAT32 partition to NTFS. Follow the steps below for Windows XP:
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At the command prompt, type the following, where drive letter is the drive that you want to convert: convert drive letter: /fs:ntfs For example, type the following command to convert drive E to NTFS: convert e: /fs:ntfsNote If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES.
  3. When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER: The type of the file system is FAT.
    Enter the current volume label for drive drive letter
  4. When the conversion to NTFS is complete, you receive the following message at the command prompt:Conversion complete
  5. Quit the command prompt.
Sep 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cannot format Removeble Disk
even i have similar problem.
I tried following command from command prompt:
format F: /FS:FAT /Q /X
and it worked.
where:
format => command to format drive
F: => drive name
/FS:FAT => command to use FAT file system
/Q => to perform a quick format
/X =>dismount the voulme forcefully
Jul 30, 2008 | Electronics - Others
Format
That is Becose your Windows sys dir is on in that drive mostlikely so you will need to format it from another os or from the installer of a os or mabey from a recovery CD
-Rel
May 28, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
David Payne
David Payne
