I need a tuning dial bulb for a TU 417 tuner (SANSUI).
5 Suggested Answers
  • 4234 Answers
SOURCE: need a place to buy
Try MCM Electronics (mcmelectronics.com). They have all types, one of which will fit your unit.
Dan
Posted on Apr 01, 2008
robotek
  • 1512 Answers
SOURCE: Sansui 9900Z. Tuner does not
Hi aline1929
This is an early synthesised tuner built in the early 80's. In saying that, it is still a revered receiver for performance and sonics. It will have a fault in the in the divider stages of the freguency synthesis circuit that will need a tech to have a look at for you. Frequency synthesis faults can be difficult to repair if you do not have previous experience. Where abouts in the world are you and I will try to steer you to someone that can help you to repair the problem.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
SOURCE: My Sansui G-7700 receiver is
Try extending the antenna to a new location or using a better quality antenna. If that does not work then you will need to replace the chip inside that controls the digital tuning. After a few years these are known to fail. Click on the link below to read more:
http://audiokarma.org/forums/showthread.php?p=4231642
Posted on Dec 24, 2010
SOURCE: Miniature dial panel bulbs for Onkyo TX-2500 Mk II
I am looking for the tuning indicator lamps 5 or 6 forgot exactly how manyfor onkyo 2500 they are about 1 inch long and clip into a metal base at both ends.help sorry this is not a solution but a problem thank you chuck.
Posted on Jan 24, 2012
What type of connection wires do I need to connect a sansui au 9900a intergrated amplifier,and the tu9900 stereo turner to a kenwood multi cd player and a JVC td- w 5th double cassette.
You need cable called RCA. What goes out of one unit goes in to another. Get the owner manual and read it. It will show you how to connect the wires to the components.
Connect the RCA jack to to tuner input in back. CD player to the aux in back.
Try this:
http://stereobarn.com/how-to-connect-a-stereo-system1/
Sep 29, 2014 | Sansui Vintage Tu-9900 Legendary Amazing...
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
Hi, sometimes, when I try to tune my Martin D15, the tuner is just going crazy, it's kinda impossible to tune my guitar, wrong note appears on every chord I play. My Boss Tu-3 is brand new. I read the...
Could be the level from your guitar is too high OR low. Too low the tuner can't get reliable signal... Too high and the tuner will see harmics of the strings. Make sure you set onboard shape or EQ's flat. You CANNOT tune while playing CHORDS... A single note at a time please...
Sep 09, 2011 | Boss TU3 Tuner
Brand new chromatic tuner tu-3 pedal, plugged guitar into input and it powers on. Guitar plays through the amp, but when I hit the footswitch the check light and tuning bar do not light up.
Change the battery first. It could be dying and just barely have enough power to come on at first, but not to do anything else. If that doesn't solve it, you've got a defective one and you can go exchange it.
Feb 24, 2011 | Roland Boss Tu-3 Chromatic Tuner Tu3...
The only way i can tune is if i have absolute silence in my practice area. if the bass, drums or lead guitar player are just playing barely it throws the tuner completely off. is this a common problem or...
Common problem... your strings wil be excited by the surrounding noise... If you cut the gain down on your guitar to a minimum needed for the tuner to see it, that should help. If you have an acoustic guitar, the pickups in those are really sensitive to local noise and you may not be able to tune if there is much going on.
Jan 13, 2011 | Roland Boss Tu-3 Chromatic Tuner Tu3...
Chances are they are LED. Check with Radio Shack or online you can check www.1000bulbs.com Hope this helps
Sep 21, 2009 | Audio Players & Recorders
Sansui DFTV275A
A DFTV275A has a built in digital tuner and does not need a converter box.
Sep 18, 2008 | Sansui D 27" TV275 TV
I have 1 1959 zenith stereo and the tuner needs repaired, i have it apart. and there is a broken string on the end of a small metal spring, how do i put it on the tuner. i can turn the tuner wheel by hand,...
1......Use new dial cord, old dial cord becomes brittle and glazed over the years.
2....the tuning knob shaft should have 2 or 3 turns of the dial cord wrapped around it.
3....the tuning knob shaft should be clean.
4...if there are any small pulleys that the dial cord rides on for smooth operation, they should be clean and free turning.
The biggest things ( as you might have guessed ) are that everything that has the dial cord running over it should be clean and free to turn if necessary.
The little spring is there to keep tension on the cord, otherwise it would loosen once it streches with age.
If you need dial cord, I believe Sony still has some. You may need to contact the Sony parts distributor for your country, but I firmly believe that it is still available.
Good luck......Rob
Mar 04, 2008 | Audio Players & Recorders
41 people viewed this question
 Grubhead
Grubhead
