Question about Samsung SyncMaster 753S 17" CRT Monitor
No display in the monitor after switching on of the computer
My monitor is Samsung SyncMaster 753s. I am not getting the video output in the monitor. Monitor switches ON. Monitor responses to Self Test is OK. I can adjust the visibility parameters by browsing thru menu function in the Monitor. Blinking LED gets steady whenever computer switched ON. but only is there is no Visibility in the monitor. Plz somebody suggests me what could be reason and corrective action
    Problem Solver:
  • 18 Answers
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors:http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps:http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit:http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Aug 17, 2014
Posted on Apr 26, 2010
Samsung sync master 753s i want size in inches
Hi, The Samsung SyncMaster 753s is a 17" CRT Monitor that has a native resolution of 1280x1024 and with exterior dimensions of: (WxHxD) 16.2"x16.4"16.5"
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung syncmaster 753s display wibration
increase refresh rate
if that does not solve,
take help of a service technitian,
you need a lot of knowledge about electronics to solve it
Jan 28, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
My Samsung syncmaster 730a monitor wont come on. the green light is solid but screen is black. could i have done something or might it have gone bad?
Hi friend,
You need you check your display cable. it should be connected in your CPU. sometime cable lose in CPU..then monitor not given any display ...
Dec 20, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor problem
try running your OS on safe mode then reconfigure your monitor on the display settings and adjust the screen resolution to sync your monitor with your video card.
Sep 02, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Removing the back cover of a Samsung SyncMaster 753s
there is 2 lock on front side first remove back side lock or scrow then insert small pin pull up back cover your monitor will get open
ashok
Jan 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
441 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
