Question about HP DeskJet F380 All-In-One Printer
Printer is not printing
The printer just comes on and do not print
  • 713 Answers
Hi,the problem you are experiencing might be either a software or hardware issue.The solution provided below will take of it;
First, check the software by updating your printer drivers.
To go there, Right-click My Computer --> Properties --> click hardware tab --> click device manager --> click on Ports --> double click on printer port.
Now check to see if the status window says it's working probably. You can click on the driver tab to update the driver.
If the problem remains it means its a hardware problem; You have to check the ink toner in the printer,probably the printer is running out of toner.
You might have to replace the ink cartridge,this might also be responsible for the problem you are experiencing with your printer.
Thanks and take care
Posted on Apr 23, 2010
Spools and prints but not printing.
Does a label come out of the printer?
Mar 03, 2014 | Intermec EasyCoder 501XP Printer
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
Prints are not coming out. Meaning when I print,
check for papers jams usually at the back of your printer thats the reason its not printing
Jun 26, 2010 | Epson CX8400 All-In-One InkJet Printer
My printer will not print. The red light comes
My printer will not print. The red light comes on, but there is no paper stuck anywhere. The toner light comes on, but when it did print yesterday, it looked fine. Please let me know what I need to check. Thank you,
Feb 15, 2010 | Brother HL 5140 Laser Printer
I can't get my printer to print. Every time i press print it tells me that its started printing then says printing complete and nothing comes out
i can't get my printer to print. e very time i press print it tells me that it's started printing then says printing complete and nothing comes out.
Feb 01, 2010 | Lexmark X5495 Printer
P3150 printer runs but doesn't print
Are you saying that the printer prints in B&W but not in color, or only that it will print a test page with B&W? It might be that the color ink cartridge is dry.
Apr 20, 2009 | Lexmark P3150 All-In-One InkJet Printer
Printhead light comes on
if you are using software that using printer please the s600 printer driver to direct thermal mode to solve the problem.
Aug 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
Mar 27, 2008 | Compaq Inkjet IJ650 Printer
RE:Cannot print in documents
It's one of two problems, either the nozzles in the cartridge are clogged or your printing preferences are set to "print in grayscale." To clear the nozzles try running the printer through a "deep cleaning" cycle from the printer's maintenance screen (available from the printer's properties). To check the printing preferences go to the printer's properties, as well, from Start > Control Panel > Printers & Faxes > right-click on the printer and choose Printing Preferences. Make sure to uncheck "Print In Grayscale."
Nov 11, 2007 | Compaq Inkjet IJ650 Printer
HP DeskJet F380 All-In-One Printer Logo
Seeker5211
Seeker5211
