Question about Acer Aspire 7720 Notebook PC
How do you stop acer e managment asking if you want to turn off wireless device when i unplug my laptop? tried in the power options and on wireless card options.
Yahoo messenger problem
Posted on Apr 23, 2010
Wireless card not working ze4933
f you suddenly have a problem with your network connection, before you make any changes, you must determine whether you have a problem with (1) the wireless device on the computer, (2) the connection between the computer and the network , or (3) the connection from the ISP provider to the network. Each of these devices / connections must be operating independently before they can all work together.
  1. View the wireless icons in the system tray to determine the status of the devices and connections. Then, open the appropriate utilities for detailed information on potential problems. The detailed windows are: the Windows Wireless Network Connection, the HP Wireless Assistant, and the Device Manager.
  2. When you have the detailed information, identify the specific type of connection problem by reading the connection description statements below. Then select the statement that most closely describes your problem for a detailed explanation of the corrective actions.Internal wireless networking adapters or PCMCIA cards may have problems connecting to a wireless network if the Advanced options are not set properly. For instance, some PCMCIA devices can adjust the power output to increase the strength of the wireless signal.note.pngNOTE:If the computer and router are in the same physical area, you may want to reduce the signal strength to save battery. However, if they are not located near to each other, you can turn the power up to 100% to maximize the signal.Most HP internal wireless cards can be set to turn off to save battery power. If the wireless connection was working but suddenly stopped when using the battery, the card may be turning itself off exactly as planned. You can use the Device Manager to specify the power settings and keep the wireless card turned on.To verify and change the wireless device settings in the Device Manager, do the following actions.
    1. Click Start , Control Panel , System , Hardware , and then Device Manager .
    2. Click the plus sign (+) next to Network Adapters . If multiple devices are listed, you should check the devices one at a time.
    3. Right-click on the network adapter, and select Properties .Select the Power Management tab, if available, and verify the power settings. Not all wireless device drivers have a Power Management option.
    When you have set the Power Management options, close the Device Manager, restart the computer, and attempt to reconnect to the wireless network.
Sep 21, 2011 | HEWLETT-PACKARD Pavilion ZE4933 Laptop...
Cant get the 5100 to connect to the internet.
Can you be more specific please ? i.e, is it the first time you have tried (new laptop) or has this problem just started (new wireless software added recently??) .. I do remember an old problem on acer's a couple of years back they had a power saving option on the wireless adapter that would turn itself to maximum by default. You could try this as a possible quick fix or give me some more info and I will try to help: right click my computer / properties / hardware tab / device manager… then find your wireless adapter in the list under Network Adapters, right click / properties / advanced tab. Select Power Save Mode from the list on the left and select Off from the drop down on the right. Press OK and close device manager.
Let me know how you get on, but with more info I might be able to help
Apr 30, 2010 | Acer Aspire 5100 Notebook
How do i turn the wireless back on my acer aspire 5410?
go into the software options and keep the wireless on always. On my Aspire I changed this setting thry device manager and everything worked much better. Power savings option shuts off the wireless too often.
Sep 14, 2009 | Acer Aspire 5050-5410 Notebook
I can't get my Acer Laptop to set up Linksys wireless internet
Try the following first power cycle the netbook (take off your battery and unplug the unit then hit the power button a couple of times b4 putting power to the netbook). After that power up the machine and try to connect.Also go into the power settings and set mt wireless card to off on the "power save mode".The "power safe mode" options are explained further below.Hope this works for you
Turn the network adapter power save mode to off,here are the steps:
- click "Start"
- click "Control Panel"
- click "Classic View"
- doubleclick "System"
- select "Hardware" tab
- click "Device Manager" button
- click "+" to left of "network adapters"
- doubleclick "Atheros AR5007EG ...."
- click "Advanced" tab
- select "Power Save Mode"
- select "off"
- select "OK"
Apr 18, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Touchpad wont work on mains power
In the acer power management in the control panel you can specify when the mousepad turns on and off, like when plugging and unplugging the laptop. You can also do this for the wireless and other settings.
Mar 23, 2009 | Acer Aspire 3610 Notebook
Power cables loses wireless connection on Acer Aspire 5100
please check your power configuration profile under control panel.
the device might be disabled when the power input is on.
If you are using, Acer's e-manager then you can confirm there as well if the device is disabled under Power on mode.
Hope this helps.
Thanks.
Mar 17, 2009 | Acer Aspire 5100 Notebook
Wireless not connecting when 6930 running on battery rather than mains. This is apparently due to low signal strength, or no response from the router, but with the main plugged back in it connects again.
This is due to the power settings of your wireless adapter.
Right-click "My Computer" and choose "Manage". This opens the Computer Management console.
Go to "Device Manager" and find your wireless adapter.
Right-click and choose "Properties".
One of the tabs should have a "Power Management" setting, which says "Allows the computer to turn off this device to save power".
Uncheck this option, if you don't want your computer to turn off your wireless adapter when running low on battery.
Dec 17, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Wireless switch
try downloading the latest driver for the device, from the manufacturers website.
There are different wireless modem cards, in different laptops.
Try This:- go to MyComputer/Control Panel/System/Device manager. if you have any yellow exclamation marks by any of the devices, then they are not functioning correctly. either re-install the driver. Or uninstall reboot the computer, when the hardware wizard detects the device, you will get options to search/ re-install driver et,c.
thankyou for using Fixya.
Mike @ compurepair.
Nov 25, 2008 | Acer Aspire 5315 Notebook
Wireless Network Card
how old is the laptop and did you turn on the wireless switch located on the exteiror of the laptop ?
Jan 28, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 7720 Notebook PC Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
