Question about Philips Televison & Video
My tv only works when i switch the room light on
    Scholar:
  • 103 Answers
It sounds to me like you have the tv set plugged into a switched outlet. To check this, I suggest you plug a different device (such as a lamp) into the outlet and see if it does the same thing.
If possible, try plugging in the tv to a different outlet.
Der Strom
Posted on Apr 23, 2010
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Light switch affects picture source
hi your tv may be set up on eco mode, there is a light sensor built into
your tv this detects the room light and adjust the picture to suit the light hope it helps
regards
shaun
Jan 16, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
Sony bravia tv constantly changing channels
Is the tv new or has it started to do this recently ?
Try to eliminate the obvious.
Does the remote continue to flash when you release all of the buttons? Is it a stuck button ?
If you cant' see the remote output, try using your smartphone camera. Most phone cameras will capture infrared light ( invisible to the eye). Aim the remote at the camera and see if you can see the flashing light, which is data being sent to the tv. When you release the buttons does the flashing stop ? If so remote is ok
Next turn all of the lights off in the room with the tv. Also turn off any lights that may shine in from other rooms. Try using the remote
If your tv functions normally, you may be getting interference from your lighting. Some LED and CFC fluorescent lights flicker at a rate which may be close to the remote IR output frequency.
If turning off the lights fixes the issue, turn on each light to isolate the issue. Replace the bulbs with ones from different manufacturers.
Let me know
Oct 24, 2017 | Sony Bravia KDL-26V4000 26 in. HDTV-Ready...
Track lighting remote control similar to that of ceiling fan?
Yes, but the remote operates on the switch that turns the lights on and off. Lutron has this kind of technology and it is really cool. I have it all over my house and I don't even have to go room by room turning lights off; I just push a button from my bedroom. Along with a single remote that can be used with each switch in your house, you can program a house remote that controls the lights and ambiance of every room.
Jun 03, 2010 | Universal Remote Control Hampton Bay...
My evesham tv wont come on/ it appears to come on but few lights flash then it knocks straight back off
We had this problem, everytime we switched it off at the main plug, so when we could, we would leave it on standby. On this occasion we had to switch it off completely, but when we tried to switch it on again it wouldn't come on. So we put the t,v in another room, a much warmer room, and after leaving it for a few days hey presto it started to work again.
May 24, 2010 | LG 52SX4D 52" HDTV
LCD TV blanks out when I flick the switch for my room lights
Do you have surge protector installed? If not, you should use one, something like MONSTER CABLE.
Nov 27, 2009 | Televison & Video
TV flickering when I turn a light bulb on in the same room
this is a sony feature, they have a sensor on the front of the tv to measure ambient and adjust the tv brightness to the ambient light.
if you want to turn this off?
call sony or put some black tape over the sensor.
R
Nov 30, 2008 | Sony PFM-42X1 Plasma TV
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
