Question about Whirlpool AWZ410 Front Load Washer/Dryer
Door of my Whirlpool awz410 1000 does not lock after putting in laundry for it to start washing?anyone knows?it used to lock after closing but now just doesnt lock and my laundry is pilling
I took out the filter in my whirlpool AWZ410 and cannot get it back in now. It just does not lock home. If I use the machine it floods out through the filter.Any suggestions please?
Posted on Jul 08, 2010
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Failure Code of F-28 and the door is stuck
F-28 refers to a sensor that has gone bad.
You will need to call a service repair man.
John
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool duet
On the far right sode of the control panel there is a unlock control reset button. Hold it for 3 seconds and the fault will clear.
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet won't run
The trouble could be with the door interlock. When the clothes were jammed in the door it could have caused the door latch to put strain on the interlock.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Door sensor broken?
Sounds like you, indeed, have a broken door latch. If the latch is not able to lock successfully, it will not go into any wash cycle and will exhibit the symptoms you are describing. The door was designed to be closed gently, not slammed or forced. To replace, you will need to do the following: 1. Unplug the machine. 2. Remove the bottom kick plate. 3. Remove the rubber door boot from the around the door opening. There should be a wire hoop holding it into a groove with a small tension spring located at the bottom of the door opening. Feel around the rubber lip and locate the tension spring. Stretch this spring and pull the wire hoop from the groove. 4. Remove the rubber boot from the outer seal and push towards the inside of the wash tub. This will give you access to the inside of the machine casing. 5. The door latch is located inside the casing on the right hand side. There are three screws holding it in from the outside and a wiring harness and retaining clip holding it from the inside. Use care when removing the wires from the old latch. The wires are small and can break. I hope this leads you in the right direction. Let me know if you need any further advice.
Jun 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
205 people viewed this question
Dan Webster
Dan Webster
Sal De
