I have a Sony Model KDL52WL130 that has a red vertical line about a inch fron the RH side of the screen. What are some of the possible causes?
  • msheared Apr 23, 2010
    I want a 2nd opinion.
  • msheared Apr 26, 2010
    Thanks
  • 10,865 Answers
Hello. Your symptom indicates that the LCD panel needs to be replaced. This is a costly fix. Please get an estimate before you have the work done and compare the repair cost to the cost of a replacement. If this Sony is over 3 years old, I do not recommend a repair. Your problem has plagued Sony incidentally. Joe
Posted on Apr 23, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
What causes vertical lines across the screen?
Lines across the screen is mainly caused by a display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 18, 2016 | Sony Televison & Video
My Sony Tv model EX31 shows vertical line ( white and black) on left and right side. 32 inch. How to solve the problem.
Oct 21, 2016 | Sony Televison & Video
My Sony Bravia KDL-46W-5100 has developed vertical lines. Any advice would be most appreciated.
Oct 07, 2016 | Sony Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Bravia KDL46w5500. Why does it display vertical lines all over the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 30, 2015 | Sony Televison & Video
Why 2 vertical red lines down right side of picture
Line, screen faults & possible causes to LCD screen are given with illustrations.
Jul 30, 2014 | Sony BRAVIA Televison & Video
Have sony model KdL 40S2000, now has colored thin lines going up and down on the left side. Anyone know the cause.
Line faults & possible causes to LCD screen is given with illustrations.
Jul 29, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
Our sony brava 52inch flat screen tv 2007 model has a red 4 inch vertical line on the left side of the tv what is the cause?
This is an internal problem with the screen itself, caused either by the connector from the "Inverter" board to the screen or as in most cases a problem within the internal workings of the screen. In most cases the only cure is to have the screen replaced which can be very costly. As it is 3 years old it is probably just outwith the manufacturers warranty for the screen & therefore would not cover the cost of a replacement. Nowadays it is can be more economical to buy a new TV altogether I'm afraid.
Nov 26, 2010 | Sony Televison & Video
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
