Question about Dell E153FP 15" LCD Monitor
Need to get screen size to show all . cant see
Need to get screen size to show all . cant see bottom task bars
  • 16 Answers
Things to check: Are your display settings set to "native resolution" of your screen. The native resolution is the actual dimensions (in pixels) of your flat-panel screen.
Looks like the Dell E153FP 15" has a native resolution of 1024x768. In windows, go to your control panel, in display settings, and ensure the resolution is set to 1024x768.
If that does not work, you can try the "auto adjust" feature on the monitor. On many Dell monitors, you can get this by pressing and holding the + button (on the monitor). You'll see the words "auto-adjust" appear on the screen if this works. If that doesn't work, you may be able to find auto adjust by navigating the menues in your monitor's menu, which you can get to by pressing the "menu" button on your monitor (sometimes this looks like a little rectangle icon). If it's an alignment problem, this should fix it right away.
If neither of the above work, it's probably your video card. Make sure your video card drivers are the correct ones for your card and OS, and up to date. You can also mess with display options under Control Panel > Display, under the "settings" tab, and at the bottom click the "Advanced" button, and it will bring up the advanced settings for your videocard.
Posted on Apr 23, 2010
How to lock the task bar when it does not showing on screen
It may be set to auto hide. Try moving your mouse cursor to the edge of the bottom screen. If it doesn't show up, try the other three edges of your screen.
Once located, right click on the task bar and choose "Properties" from the menu. On the window that pops up, simply uncheck the auto hide option. If the bar is already on the bottom edge, click on the "Lock the taskbar option." If not, drag the bar to the edge of the screen you prefer and then lock it.
Jul 04, 2016 | Acer Extensa Computers & Internet
Lenovo b640 model the tool bar is showing on the top but as is drag it on the bottom it is hide or not showing but it is showing on the right and left of the windows 7
Hi
Try right clicking on a part of the task bar and checking that the "Lock Task Bar" is not ticked in the menu that appears, untick it if it is. It shouldn't be as you can drag it to the left or right of the screen. Then click "Properties" and check that the "auto-hide task bar" is not ticked. Again it shouldn't be but untick if it is.
In these circumstances you should be able to drag the task bar to all four sides of the screen and it should remain visible at all times. If it is still not showing at the bottom of your screen, I would suspect that your graphics card is setup to show a larger screen than the actual screen can display, and you need to right click somewhere on the desk top and look at "Screen Resolution" (win7) to see what the settings are and what you can change them to to try and bring the task bar back into view when it is on the bottom.
Do any of your programmes lose their lower parts when viewed full screen?
On today's wide screen profile machines, I often find it better to have the task bar on the side. It takes a little getting used to at first, but after a while I found it more natural than at the bottom.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 09, 2014 | Computers & Internet
Show task bar on computer
What is the operating system? For Windows 7 and older, move the mouse down to the edge of the screen and see if the task bar slides up. If it does, right-click on it and from the scroll down list, select properties. From the pop up settings box, remove the check mark on the Auto-hide the task bar box.
Now the task bar should be ever present at the bottom of the screen.
Sep 03, 2014 | HP EliteBook 8560p Notebook
Why do my icons don't appear in the lower right, I would like to reinstall day date calander and time
It is not very obvious. The bar at the bottom of screen is your 'Task Bar'
1. Find an empty part of your Task Bar and Right Click on it
2. Select Properties
3. Near the bottom of the menu in 'Notification Area' tick Box 'Show clock'
While you are there, it shows all icons that are on your Task Bar. If empty find the 'Hide Tasks' box and untick
4. Tick Apply and OK
May 30, 2014 | Lenovo Computers & Internet
Start tast bar disappears
Right click (hit right mouse button) on task bar and click to lock task bar and uncheck hide task bar. If you cannot right click on time before it disappears move pointer to the bottom of screen and it should reappear. Than follow above steps. If all else fails restart computer clicking on the F8 key repeatedly until start menu comes up , choose safe mode and when the computer starts up your task bar should remain in place, follow above steps to unhindered it permanently and reboot the computer it will start back up in normal mode and your task bar should be "fixed"
Feb 05, 2013 | Lenovo ThinkPad T410 Notebook
How to get the task bar to it natural size?
It is possible to make the task bar taller than it is by default, and this is the only way that I know of to change the size of the task bar, so I have to assume that you are asking how to take the task bar back down to the original "tallness." You would put your mouse cursor at the top of the task bar until it turns into a double-headed arrow, and then click down and drag the top edge toward the bottom of the screen until it is the normal height. If the task bar is locked, this cannot be done, so make sure it is unlocked by right-clicking on an empty spot on the task bar and make sure that "lock task bar" is not checked first.
Jun 10, 2011 | Microsoft Windows XP Professional Full...
Sidebar has suddenly moved to side affecting size of screen. How do I return it to bottom???
You are probably talking about the windows Task bar that normally resides at the bottom of the screen:
Two ways of moving this task ba, to top/bottom/letft/right position of the display:
  1. Move the cursor on a blank/inactive area on the task bar, usually in the largest blank area towards the right, click and hold the right mouse button and drag the Task bar to the bottom of the screen.
  2. Go to the Task Bar 'Properties' (You can get this context menu by clicking the left mouse button after putting the cursor on a blank/inactive area on the task bar) and change the 'Task bar location on screen' option.
Hope it helps: let me know how you go.
Dec 17, 2010 | Toshiba Computers & Internet
ON mini 10 the bottom of the display doesn't show, where the start button is.
you might have change the location of the start menu or called task bar, try to press the windows logo key on the keyboard to show up the task bar. if it shows up you can drag it to the bottom of screen. if it is locked and cannot be dragged, right click on it and remove the check mark on lock the task bar.
Mar 09, 2010 | Dell Inspiron Mini 10 Notebook
I cant find my task bar that is located on the top of my screen
press the windows logo key on the keyboard to show the start menu maybe you have dragged the task bar on other part of the screen or it is hidden
Feb 26, 2010 | Dell Inspiron 1525 Notebook
I HAVE A WINDOW XP HOME EDITION AND WHEN I START MY COMPUTER THE ONLY THING THAT COMES UP IS THE BACKGROUND. THERE ARE NO ICONS OR A BAR AT BOTTOM OF SCREEN.
the icons and the bar(task bar) at the bottom of the screen are enabled by the explorer.exe file
it starts automatically but in your case it is not starting
to start it when your computer starts and comes at the desktop, press alt+ctrl+delete button at the same time to bring up the task manager
when you do this a task manager shows up in a window
in task manager window click on file, it will be located on the top left portion on task manager
now click on "new task(run)"
this opens another window, in that window type
"explorer"
without the quotes "" and press enter
this will bring you icons and task bar at the bottom of the screen
Sep 29, 2009 | Computers & Internet
Dell E153FP 15" LCD Monitor Logo
125 people viewed this question
Alun Cox
