My mp4 device wasn't recognized by the computer..what should i do?
  • 3 Answers
Hi Lopez,
First see if USB entrance you are using on your PC is working, some times you can have 3 or 4 USB portals/ connections on your PC but only a few work (seee front and back).
Second check if your USB cable is not damaged, try conecting another device that will work, so you´ll know USB and cable are working properly.
Then let me know which MP3 you have and I´ll tell you how to make it work.
Best,
Louise Passalacqua.
Posted on Apr 23, 2010
Usb will not show avi movies?
One must remember that smart TVs are not computers. While they have a processor and can perform many computer-like functions, they are limited in what they can do to what the designers embedded in them. Many TVs can only read MP3/MP4 type encoding, and will not recognize other types such as .avi or .divx. Check your smart TV manual for a list of what file extensions are supported. If you have a computer, you can get converter software (often free) that will convert the file format. Then you can convert to a file format that is TV-friendly.
Mar 03, 2015 | Televison & Video
I opened a brand new mp4 model 715 , i cant get my computer to recognize it and when its plugger to the computer all it says is please wait, i have reset it and it only displays please wait?
Did you get a device driver CD along wit the MP4 player? If yes, then install the software before inserting the mp4 player to your computer.
Jan 17, 2012 | RCA Audio Players & Recorders
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Craig touch MP4 player and it is not recognized by computer.
try using media and click the sync tab
wait for the new device window
name it and your done
Dec 31, 2009 | Audio Players & Recorders
My comp. doesnt recognize my premier mp4
The computer recongize it as a removable disk.
plug in your mp4 player
click start
click computers
click removable disk
formate the disk
copy and paste you songs.
Dec 23, 2008 | Premier MP4 Digital Media Player
Usb device
Try another USB port or another computer altogether. For some reason there are some drives that some computers see and others that they dont.
Hope this helps
Jul 21, 2008 | Electronics - Others
Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Dec 20, 2007 | Samsung YP-T8 Digital Media Player
27 people viewed this question
 Grubhead
Grubhead
