I have a kenstar little cooler plus it has a water tray/tank on the top of it and a water level indicator near the bottom of the unit. i`m not sure whether I should put water in the tankor whether it collects water? Thank you
  • 34 Answers
If it is a portable air conditioning unit, the tank will fill up with water as the unit pulls humidity out of the air. you will need to empty it when it gets to the full mark
Posted on Apr 24, 2010
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
Oct 29, 2013 | Refrigerators
I have an SA12059 Windchaser portable a/c. After using it and rolling it around, the top condensate tank drips lots of water. I tried to drain the bottom tank via the hose, but the top tank doesn't seem...
There is not actually a top tank, just a drip tray with little drain holes that become easily clogged. After removing the rear cover of the unit and cleaning thoroughly, you can use a can of air (like the ones to dust pc's) wth the little straw attachment to try to clear te clogged drain holes in the tray below the evaporator. If your unit froze up condensate may have overflowed into the fan area. Let the unit defrost, and run it in fan mode for awhile to dry this moisture out.
Sep 01, 2013 | Windchaser PAC9 Air Conditioner
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
Saeco Talea Giro Plus, descaling following instructions step by step. In step 12 the descaling light did not turn off. The warning light came on as indicated. In step 15, pressing the descaling button...
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
Mar 26, 2011 | Saeco Talea Giro Espresso Machine
Icemaker will not dump
Make sure it isn't damming up on one side or another if it is you will need to level the ice tray...you might try to leve the refrigerator first, but if that doesn't help you will have to loosen the screws on the ice tray itself and level it may sure the water is level in the tray.
Oct 25, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer leaking water
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Aprilaire 700 leaks water from bottom of case
Install new water panels yearly. On the new panel make sure that the painted dot on the edge of the panel is on the top when you install it.
Always clean the distribution tray and the frame. Make sure the notch on the edge of the distribution tray faces away from the furnace. Make sure the humidifier was installed level. Keep the drain tube opening clear. Insure there is no blockages in the drain tube.
Good luck
HVAC Teacher
Feb 10, 2009 | Aprilaire 700 Humidifier
Replacing micro switch
You have to take of the top, there are several screw to loosen.
  1. Take off the water tank and bean hopper
  2. Take out drip tray and dregbox
  3. loosen the two screw in front where the dregbox and driptray was ( one in each corner)
  4. Take of the plastic adjustment in the right corner (grinder adjustment)
  5. Loosen the screw in chassi where the water tank was, look inside where the beanhopper was to make sure there not are a screw, some models have one there. If there are one you will see that behind the grinder.
  6. Take off the plastic on your steam pipe.
  7. Take off the top.
  8. On the right side near the hole where you put pregrounded coffee, there will be a little microswitch.
I hope this will help you
Jul 14, 2008 | Saeco Royal Digital Plus Coffee...
Hoover SteamVac Model F6056-900 SteamVac/SpinScrub. Indicator light and high pitch suction noise indicates that dirty water tank is full. However, water level indicator (yellow bobbing plastic thing) is...
There are 2 filters, make sure they are clean, one is on the tank lid, the other is from the bottom, it is red, pull it out and clean it. If yours has a foam filter on the tank lid covering the yellow ball, make sure there is at least a 1/4 in. gap from the top. Also make sure that the lid in on and secured tightly.
May 26, 2008 | Hoover Vacuums
Unit turns off Mid Stream
The part of the machine that draws water up from the bottom, as well as the bottom tray, need to be cleaned from time to time, or it cannot accept water and will indicate the tank is empty. After removing the tank, unlock the top from the bottom by moving the small lever in the area the tank sits, then pull the entire top section off of the bottom tray. Dump the old water out, then put a solution of vinegar and water in the accepting section of the tray. Replace the top and let that set for a few hours to remove buildup. You may need to use a silicone scraper or something if there is significant buildup. Pour out the vinegar solution and rinse all of those sections off with clean water. Replace the top, lock the bar, and return the tank. Your problem should be fixed.
Oct 14, 2006 | Honeywell Warm Mist HWM-255 Humidifier
Heating & Cooling Logo
420 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
