Question about HP Pavilion a1110n (PX743AA) PC Desktop
Hi, The memory was originally working fine it has two 512mb in there, I have tried another one from a working ibm desktop and the problem of continuous beep still exists. Please help
  • raj_randhawa Apr 23, 2010
    These memory sticks have been working fine in the computer for over 3 years, and have been tested in another machine
  • 109 Answers
Before installing memory module into the system check the FSB of the module it should be according to the motherboard manual
Posted on Apr 23, 2010
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I need ibm m51 8141 drivers .
FAQ
IBM M51 8141,8142,8143
Max. Processor = INTEL P4 670 ( 3.8GHZ) 2M HT = 64 BIT SOC.775
Max. Compat. Graphics = ATI X700 pro/256- 512MB / PCIex16
need no extra Powercable, works with original 310W Powersupply
Jan 21, 2011 | IBM ThinkCentre M51 PC Desktop
I went and bought new ram for my computer. it's an IBM desktop. type 6792. a pc133 512MB sdram. my computer will not pick it up. how do i get the computer to pick up the ram? it is the right kind of ram?
I checked at http://www.buffalotech.com/products/memory/select/select-dimm/ and according the the memory configurator there your IBM Netvista 6792 takes this type of memory which can be ordered from them PC-133mhz SDRAM DIMM 168 pin, it indicated that your pc has 3 slots for memory and the maximum size you can put in each slot is 512 MB which would give you the maximum memory of 1536 MB. I have had problems in the past when replacing memory in IBM PC's some modules won't work because IBM uses different memory than other Manufacturers. But give Buffalo a try, their memory is guaranteed.
Apr 05, 2009 | IBM NetVista PC Desktop
Ram upgrade problems IBM netvista 6794
You can try this site, it scans your system to see if your computer can run more memory than what is currently installed. it helps you find the right memory modules for your system and and an option for you to read reviews if available and if you want to buy it.
try this site: www.crucial.com
Please rate this solution
Dec 26, 2008 | IBM NetVista PC Desktop
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
I have same problem as ninja9er
hi,
First try Using one at a time, since its not advisable to use memory chips with variable bus speeds i.e (333 & 266).
Since IBM Computer are little complicated i would suggest your to call the customer care or Tech support for assistance in buying a Memory module. In that way you can cross check the memory module you have bought is compatible with the computer.
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 22, 2008 | IBM NetVista M42 PC Desktop
Memory upgrade
no jumper just touchy mobo on ram u buy u have to buy ram off ebayt samsung low denstity 64x64 chip config ok like i did and it workeed mark this as fixed ya so others can get same help thx nick
Jan 30, 2008 | IBM NetVista M42 PC Desktop
IBM NetVista A40 Memory Upgrade
It would be advisable to go to the IBM website and then to their support link, find the manual for your system and see what it says about memory upgrade of your system BPCS
Dec 28, 2007 | IBM NetVista A40 PC Desktop
HP Pavilion a1110n (PX743AA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
