Question about Kenmore 62802 Electric Dryer
Our dryer stopped heating so we changed element and cutoff kit, worked for 2 loads and quit, again changed cutoff kit and worked for 15 minutes and stopped heating again, what are we not doing right?
    President:
  • 949 Answers
The cutoff is there to trip if too much heat builds up around the heating element. The most common reason for this is plugged venting. But it has to do with poor air flow for sure.
- Check to make sure your lint screen is clean and nothing is fallen down the lint filter chute
- Briefly run the dryer without the vent connected and feel the air coming out the back of the dryer, it should feel like good air flow, now connect it again and feel the air where it comes out of your home, it should feel about the same strength.
- To clean the vent, you can use a long brush, a vacuum or even a leaf blower to try and clear the lint. (blow from inside out or you may make a mess inside)
Posted on Apr 23, 2010
MY DRYER QUIT HEATING AND THE TIMER WOULD NOT CUTOFF THE LAST FEW MINUTES AT THE SAME TIME. REPLACED THE ELEMENT AND THERMOSTATS AND FUSE. ELEMENT HAD OBVIOUS BREAK IN COIL. REPLACED THE TIMER AND THE
Have you reached into the back the dryer's vent port? Most will just replace the hose but fail to clean out the dryer's internal vent tube from the internal blower.
Re-check the fuse, a clogged internal vent tube will blow the fuse again.
Mar 31, 2014 | Kenmore Dryers
Dryer shuts off before load is dry. it will not turn back on for about a half an hour. is this an easy fix?
Yes it is. It is more than likely your high limit thermostat. The high limit thermostat is located on the back of the dryer after the heating element, (right before the entrance into the drying chamber). They high limit and thermal cutoff usually come as a kit because they should be replaced at the same time. The thermal cutoff is located on or around the body of the heating element. good luck!
Apr 06, 2010 | Dryers
Heat is sporadic. model DDE5900RALWH erial G246248G
Make sure lint filter is clean also frre airflow from Exhaust, if tisis ok could be thermostat or element, try basic stuff 1st...
Feb 22, 2010 | Dryers
I changed the thermal cutoff. it dried one load and then wouldnt heat again
check the thermo again, it might be going out due to a short in the element, or obstructed venting causing too much heat, clear venting or replace therm/heating element if needed.
Jun 30, 2009 | Dryers
Dryer runs for 15 minutes and stops
check the in-line limiters on the heating coil tube.
Jan 15, 2009 | Kenmore 62882 Electric Dryer
Only a little heat is going to the cylinder
Zuraxus what you are seeing is normal for a time. Here is how this dryer works. With a wet towel in the dryer, the first 5 minutes is testing to see if the load is wet. If so then between 5 & 10 minutes the dryer will turn on the 800 watt heater section (only in clockwise rotation). If still wet enough from 10 minutes to 15 minutes it will turn on the 1900 watt heater (heating only in clockwise). If still wet enough 15 to dry will turn on the full 2700 watts in clockwise and 800 watts in counter clock wise. That is how the cycle works. However it is hard to tell with the rear cover removed as the blower pushes the air thru the heater. Careful that by running with the back panel off you don't trip the high temp manual reset protector. So yes this sounds normal. What is the issue that is causing you to think the dryer isn't working proper?
Apr 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore 62802 Electric Dryer Logo
93 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
