Question about Acer Aspire 3610 Notebook
Laptop not working
The battery on the laptop is reading warning: low battery risk and even with the ac adapter connected it turns off. I removed the battery and have the adapter connected and it doesn't even power up !! Need help or advice please!!!
  • bambam04 Mar 23, 2008
    I don't understand what you mean as brick? Shouldn't the laptop work with out the battery and adapter connected ?
  • Acer Master
  • 13,433 Answers
Your ac adapter might be bad, I had to repair my own back in the day, a connector somehow got loose from the board..
Try with a difrent adapter.
Posted on Mar 23, 2008
    Genius:
  • 1,027 Answers
Do you have a different power brick to use? Sounds like the brick output no longer supplies the required voltage/amperage.
What is the DCV power output and Amperage of the brick?
and what is the Part number of the brick
  • Mark Williams
    Mark Williams Mar 23, 2008
    The brick is the external power supply. If the AC/DC power adapter that connects to your laptop no longer supplies the required voltage/amperage then it will not power up the laptop or charge the battery.
    The power adapter, if not internal, is referred to as a "brick"
  • Mark Williams
    On the ac/dc power adapter there is usually a part number or model number, my acer adapter has a model # of ADP-60XB with a output voltage of 19V 3.16A making this a 60 Watt power supply.
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
My Thinkpad A30 replacement battery is not charging and is not even being read by my battery miser program. Does anyone know why?
Welcome to FixYa!
Im very sorry to hear that, it may also be the AC adapter that you are using. Worst is the DC port, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
May 17, 2011 | IBM ThinkPad A30 2652 Notebook
My DELL Inspiron 2000 seems occasionally to cut out and shut down even when it is plugged on at the mains. I get a low battery warning and it then goes off. Often you get a green and a yellow light at the...
1.Try to check if the port (dc input jack) for the ac adapter is loose, because that could be the problem.
2. Also try to use a good known ac adapter if it will do the same thing. If it does the problem is the dc input jack. If not, the problem is the ac adapter and you need to have a replacement or have it checked.
Feb 27, 2011 | Dell Inspiron 2200 Notebook
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.Some time it boot up and run but then it won't do it nextime after it been power off. Battery for BIOS is good, Main...
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | IBM ThinkPad T30 2366 Notebook
Inspiron 1150 won't turn on. Noticed recently that battery life seemed shorter, plugging it in did not prevent it from shutting down after receiving the low battery warning, and it took a long time to re...
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 18, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
HP laptop does not start.LED on.black screen "warning-battery low
Im not sure but there is normally a button somwhere on the laptop which acts a a reboot button. normally very small and have to press it using a pin etc. You could try that then turn it on but not sure if it will help?
Jun 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Laptop will not power up with Adapter
It sounds like there is a problem with your motherboard. You would have to take it someplace to run diagnostics on it. It may be time for a new laptop
Apr 14, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Acer Aspire 3610 Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
