Question about IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR KIT-Air Brush
Water coming out airbush from hose
Im using an iwata smart-jet compressor and im having an issue of water coming out of the airbrush from the hose. I empty the catchment but its just getting worse
  • 27 Answers
To get most to all water and vapor out of your line when painting is actually easy. First you need an inline water separator, and an extra 20 feet of air hose. Run the air hose off the compressor and coil it up. Put it in a bucket of icewater. Put the water trap or inline separator on after the bucket and run hose from that to your paint gun. Put a small disposable water absorber on before the paint gun too. I painted many cars like this and had horrible water problems before I did this. Now there is basically no water getting past the seperstor. Just remember to drain separator often and draining the compressor tank before you paint is good practice also.
Posted on Sep 18, 2011
  • 632 Answers
An in-line water separator should be used before the supply line, a good air filter wouldn't hurt either.
Posted on Apr 23, 2010
Airbrush stopped spraying paint
Is the paint tube clear at the venturi?
Feb 11, 2015 | Iwata Neo for CN Gravity-Feed Airbrush
Why compressor don't start
Try pluging it into another outlet, compressor is possibly locked up, consider replacement.
Jul 20, 2014 | Harder Steenbeck Evolution Silverline fPc...
I am using an iwata eclipse cs airbrush with an iwata compressor. the comopressor seems to be working fine when power, but the airbrush is not getting and air. when i push down for air release, nothing...
Air brushes us a Theory called a "venturi" in where air pressure lowers the pressure where the paint is kept and causes it to go out the nozzle. I would try seeing if there is an obstruction in the hoses to the brush and confirm that the compressor is moving air. If none of these things are an issue also while cleaning the parts may give the appearance that the item is clean then try soaking them over night in paint thinner and replacing the O-rings and gaskets.
Apr 27, 2011 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Air compressor regulator
hi my iwata powerjet lite shut down.theres power but no performance.it only gets used for prob ten hours a week,somtimes weeks without use.is this common and expansive to repair.thank you.re ****.
May 01, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Feb 18, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
I have some severe free flow goin on, on my hpbcs iwata eclipse
It sounds like you have a problem with the air valve. Possible deterioration of the valve material? I am not sure what they use, but if it is a rubber the cleaning thinner MAY have destroyed its properties if the cleaner got into the air path and valve.
Aug 12, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
My iwata hpc is pushing air back through the paint cup
Try replacing cup gasket first then clean all inlets and outlets completely, check that all valves operate properally, and all seals and o-rings are in good condition. Clean and lubricate adjustment fluid valve.
Jun 16, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Need a new paasche spray gun for bigger jobs
Anest-Iwata brand spray equipment has the most versatile line of airbrushes on the market. Im sure you will find one to meet your needs. well worth the money, it's all I spray
http://www.airbrush-iwata.com/
http://www.tcpglobal.com/airbrushdepot/iwata.aspx
check it out!!
Apr 07, 2009 | Air Tools & Compressors
IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR KIT-Air Brush Logo
151 people viewed this question
Top Iwata Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Iwata Air Tool and Compressor Expert? Answer questions, earn points and help others
