Question about AEG B8139-4-M Electric Single Oven
MY AEG OVEN IS IN SAFE MODE HOW DO I GET OUT OF THIS MODE
Just found out that the 'safe' mode on my oven is for child protection. I had to press 'p' en 'minus' (-) at the same time for a few seconds. Problem was solved immediately. My oven is an AEG-Electrolux Micromat-Combi.
Posted on Sep 18, 2011
Thank youuuuuuuuuu!!!!!!!!!!! ??
Posted on Jun 14, 2016
Aeg manual
In order to help you turn on the oven you will need the oven manual. But as you have not provided the model number it is hard to advise which manual applies. You may want to visit this website and type the model number after you check it from the plate on the oven door. (side). AEG Service Support User Manuals
OR
if in Australia
Aug 21, 2014 | AEG Ovens
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
Hi, I have 90 AJC 06 GC. AEG single oven. At thhe moment when the oven is turned off the cooldown fan will not turn off so I have to turn it of at the main fuse box. Also sometimes the oven turns itself...
The oven cooldown fan will sometimes run for 10 to 15 minutes after turning the oven off. This enables the outer shell of the oven to cool down. Most ovens also have an inbuilt thermal overload in the outer shell. If the temperature in the outer shell gets too hot it will open circuit the oven power until it cools down a bit.
Feb 10, 2011 | AEG Ovens
My oven is locked out and I cannot get it to work
Is the digital clock/timer set correctly? Sometimes after a powercut I have to reset this to get the oven controls back into manual mode. Follow this link to the user guide for your oven and have a read. Re set the timer and should be ok....hopefully! http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/B1180-4-M%20UK%20R05-_E
May 08, 2010 | AEG B1180-4 Electric Single Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
The bottom oven has stopped heating up. In fan mode and oven mode it does not operate. The grill in the bottom oven still works.
It is probably the oven fan element that has failed.
It is located at the rear of the oven compartment behind a removeable cover.
I am basing my solution on the basis that the oven is electrically heated, and not by gas.
Feb 23, 2010 | AEG D5701-4 Electric Double Oven
In fan mode oven very slow to heat up [ fan is working] all other functions ok
If you can, test the oven fan element, if you can't, then feel \at the back of the oven compartment in front of the fan, you shoud feel hot air blowing, if not, then you need to replace the oven element.
Please rate my solution.
Thanks.
Nov 04, 2009 | AEG B5741-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG B8139-4-M Electric Single Oven Logo
4,466 people viewed this question
Top AEG Ovens Experts
ashburton
Steve
Chris Hall
Chris Hall
Are you an AEG Oven Expert? Answer questions, earn points and help others
