Question about Asko 24 in. D3350 Dishwasher
Asko 3350 F2 fault meassage keeps flashing
Keep getting the message F2 after a few minutes of running a cycle.Hve pulled dishwasher out and there is no water leaking but we have to drain machine manually
    Sergeant:
  • 351 Answers
You have a blockage try the drain spigot under the sink or the pump may be blocked.
Posted on Jun 17, 2010
Unit has been flashing F1 and now doesn't seem to complete the cycle. Just keeps running.
The F1 error codes is a water heat fault,the control has determined that within 60 minutes that the correct water temp.has not been reached
The possible causes of that are
A burnt out heat element
A burnt out thermostat
Gene
Aug 22, 2011 | Asko 24 in. 1895 Built-in Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Apr 06, 2008 | Asko D1776 Stainless Steel Built-in...
ASKO 1595
i live in australia our part no is 8052120
Mar 31, 2008 | Asko D1776 Stainless Steel Built-in...
ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Mar 27, 2008 | Asko D1776 Stainless Steel Built-in...
Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Oct 28, 2007 | Asko 24 in. D3350 Dishwasher
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
F2 fault
The F2 error codes relates to high water level It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. As well it could be a defective or a malfunction pump. Good luck!
Sep 05, 2007 | Asko D1876 Dishwasher
Dishwasher fault
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
Asko 24 in. D3350 Dishwasher Logo
639 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
