Question about Refrigerators
Kenmore indoor icemaker frozen wil not dispense ice
We used the ice maker for a week . Now the ice will not come out.
  • 3 more comments
  • 7 Oaks Mar 26, 2008
    I can not dispense ice through the door. Also I can not remove the ice caddy from the door to dump the ice . Model no.56829604.
  • 7 Oaks Mar 28, 2008
    the ice dispenser.Model 56829604
  • shasta2001 Apr 05, 2008
    The plastic part that you push to dispense the ice is just kind of hanging there. Will not dispense ice from the outside.
  • dallasgirlfr Apr 18, 2008
    I have a Whirlpool Side by Side Refrigerator and the ice maker will not dispense ice from the front door. There are no loose parts and the little door still opens, but there is no connection to make the ice machine move in order to send the ice out the door. I still get water from the front door. And I cleaned all the ice out...there is no frozen ice anywhere.
    The model is ED25UEEXHT01 and the serial is SK4544357. Thank you.
  • nayyar72 Sep 03, 2008
    My ice maker is making ice, but the ice is not dispensing on my Whirlpool side-by-side. The motor appears to turn very slow and not smoothly. Is this normal?
  • 27 Answers
Hi. I need more information to help you with your problem. Model number and a better discription of your problem. Will not come out of the ice maker itself or the ice dispenser? Thanks, Mack
Posted on Mar 23, 2008
  • themackshack Mar 29, 2008
    Hi. Your ice dispensor door is leaking air and has frosted up the bottom of the ice container. It is very difficult to remove the ice container in this condition. All you can do is push the button in on the right side of the ice container and keep tugging upward. It will eventually come loose. As far as the ice door, either the ice door insulation is worn or the door mold plastic tabs have broken that hold the ice door pin in place. If its the insulation on the ice door that is worn just replace the ice door only. If its the door mold that is broken, you will have to install a field repair freezer door repair kit. I sell them on Ebay as username themackshack. They are $39.95. Good Luck! , Mack
Whirlpool model # ed5vhexvq1 side by side maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Ice maker maker not calling for water. changed mixer valve (new) still nothing water dispenser works. the icemaker runs it rotation ok still no water coming into tray
the fill line is frozen in the freezer .remove ice maker fill line is located behind maker use a hair drier to thaw.. could be ice maker too it controls the water valve.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Icemaker keeps freezing up after a couple of weeks of using then it becomes clogged with frozen ice int mechanical part of the icemaker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
The water dispenser on the door works, but the ice maker won't make ice
Pour about 1/2 cup of water into icemaker . If it dumps the cubes after freezing , but doesn't refill with water , then replace the water inlet valve ( part that wall water line connects to on fridge ). If the icemaker does not dump and holds the frozen cubes , replace the icemaker . Also check the fill tube at the icemaker to make sure it is not frozen closed , due to a seeping water valve , and make sure the coils are clean beneath refrig of dust , lint , pet hair , etc.
Aug 28, 2009 | Kenmore Refrigerators
Remove door and icemaker from bottom freezer model 59673914200 -- icemaker wont turn
The ice maker switch had come unattached due to excess ice buildup, and frozen to the ice pack. The ice in the ice maker had also frozen into a solid block due to not being able to rotate. After removing the drawer trays and protecting the frozen food, turning off the refridgerator, I used a hair drier to melt and remove the ice from the ice maker, gave it time to dry out, -- No gears wer stripped,- the ice maker now works normally.
Aug 23, 2009 | Kenmore Refrigerators
Whirlpool refrigerator icemaker does not dispense ice cubes
I don't think the ice maker liked the water being turned off. Usually there is an arm that will raise up to a catch position that will turn the ice maker off. I hate to say it, but ice makers are best to replace than repair. The internal parts are difficult to change, and with a new one you will have no problems. They are not too hard to change. Shop around for a good deal, I use e-bay.
Apr 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
Nov 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
654 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
