Question about Kitchen Ranges
Ge profile smart water heater mod# pg50t9xa ser#geln0100135674 pilot light will not stay on
  • 776 Answers
There are couple of things that you will have to check:
1. It could be your thermo-couple.
http://www.ehow.com/how_4964289_tell-thermocouple-bad-water-heater.html
On the left side of the page you will find out instructions to check/instal etc..
2. The are no specifics regarding the "combustion shut off device". On most new heaters this device is located on the access panel. It is a button shaped device and has has 2 wires attached and a button to reset it. It may be located under the access panel on your heater.
This device should only be an issue if the pilot won't stay lit. If you can't light it at all then you probably have a dirty pilot burner orifice. A small speck of dust can find its way to this orifice even in a newer heater.
At this point you probably should open up the access panel an try a match to light the pilot. If you can't light it with a match you need to disconnect the pilot burner tube at the gas control valve and see if you have gas leaving the valve when you depress the pilot lighting button. If you do then the orfice is dirty. If you don't have gas there then you have a bad gas valve and will need to replace it
How to Clean a Hot Water Heater Pilot Light:
http://www.ehow.com/how_6323038_clean-water-heater-pilot-light.html
Posted on Apr 23, 2010
I have a GE smart water heater model GG40T6A. the pilot light will not stay lit. what can i do?
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Oct 08, 2010 | General Electric GE SmartWater Household...
I have a 40 galon GE Smart shield water heater, Model: SH40T12AVH00, Serial # GELN0805V13908. The pilot light is lit but the burner will not stay on for more than 2 secods and then shuts-off.
I believe this unit does not have a standing pilot light and lights each time? Have you reinstalled all doors back into the heater? It sounds like the main burner is blowing the pilot off the thermocouple. You might try replacing the thermocouple. You can download a manual here: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=SG40T12AVH00
Aug 02, 2010 | General Electric GE SmartWater Household...
I have a Rheem 50 gal. natural gas water heater mod#21V50-6A followed all instruction and can't get pilot light to stay lit.
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Feb 23, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
GE Smartwater Heater model# GG40T6A won't stay lit
Look and see if your pilots flame is touching the themocoupling ,if it isnt then cleane your pilot orfice.If that dosnt work replace thethermocoupler.I would also check the draw. Hold alit match or a cigerett up to the draft diverter (the air space between your heater and the vent. If it dosent draw the smoke up the vent it meanes your vent is stoped up or you need to raise it.
Dec 02, 2009 | General Electric GE SmartWater Household...
The piolet light will not stay lit on a GE Profile Smart Water heater.
Make sure there is not a direct draft hiting heater. this wil always blow out flame.
It could be thermo-cuppling. If this is bad,it wont leave gas come in to keep piolet light lite. hope this helps. :)
Jul 05, 2009 | Water Heaters
GE Profile Smart Water Heater leaking at top/no hot water
could be pressure relife valve as well- you need to tell us where water is comig from exactly in order to solve
Nov 09, 2008 | Water Heaters
Kitchen Ranges Logo
293 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
