Question about Garden
I have a weller ec2001 soldering station & the display went out completely but the irons still heat up fine, I just cant tell if the heat dial is working or just on 1 permanent temp?
  • 12,061 Answers
Ok, this is more than likely just a meter error, take the unit apart, have a look at the meter, see if it is disconnected,as you will see inside, they are pretty simple, IF the meter is faulty, simply get another from Weller, they're real cheap, and easy to install. Below is a manual, with diagrams, use this you should be able to work it out now worries, sometimes, the temp control in the element goes, and that can stop the meter too.
http://www.arcade-electronics.com/weller-ungarpartscat.pdf
Posted on Apr 23, 2010
Hello all. I just began having a problem with my Weller WD1 Soldering Station. It powers on fine and the display works, however no matter what temperature the display says it is set to it will not hea
You might want to check the iron itself with an induction power tester to see if it is getting any power to the tip. This type of tester doesn't require any dis-assembly just close proximity to energized circuits.
Feb 09, 2015 | Weller Welding Tools
Weller WES51 does not heat up unless I turn to 700 degrees or higher
You may have a broken wire in the temp sensor in the tip of the iron or near where the iron connects to the base.
Jan 24, 2014 | Weller WES51 SOLDERING STATION
Weller wd1XXX with WP80 not heating with - - - error on display HELP?
There is ceramic heating element that gives problems, and there is some kind of transformer or coil below that. I had no success in repairing the iron so I ended up replacing it. My soldering station saw two iron replacements over the years, I checked to make the station was putting out the 24volts required.
Dec 03, 2011 | Welding Tools
Weller Solder Station EC2000 display light but iron doesn't heat
Hello theree and welcome to fixya
you'll find the datasheet for your model here, including troubleshooting guide, assembly diagram and parts list: http://www.action-electronics.com/pdf/wtcpltechsheet.pdf
In my case the magnetic switch was still working (there's instructions on how to test each part) but the heater barrel was open. I replaced the barrel and the nut (the newer barrels are slightly larger in diameter, so you might as well get a barrel nut at the same time) and the iron works perfectly.
You can get these parts from Digikey:
EC234-ND - HEATER ASSY FOR A TC201T IRON
BA60-ND - ASSY BARREL NUT FOR PES51&50
SW60-ND - SWITCH ASSM FOR SOLD PENCIL (magnetic heater switch)
Some are listed as 0 quantity, but they order them and I got mine in about 2 weeks. Other replacement parts are available, but if you have to replace too much (or the more expensive parts) on the iron you might as well buy a new iron. When mine broke, I fixed it and purchased a new weller that was adjustable for $100. Now my old one is the backup, and I don't mind bringing it to electronics group meetings.
However, this is a worthwhile iron to fix if the cost is not too great. The new fancier models have more features, but you really can't beat how durable and usable these old wellers are. While you're at it, you might as well get another tip or two.
Oct 24, 2011 | Welding Tools
I have a weller EC1201A iron connected to an EC2100D base unit. It is a UK 240V model with digital temp set and display. The iron does not heat up. You can set the desired temp but the display just...
its my be the controler
http://cgi.ebay.com/New-weller-control-Board-EC1002-soldering-stations-/390286420305?pt=LH_DefaultDomain_0&hash=item5adee22951
good luck...
Feb 25, 2011 | Weller Welding Tools
I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Jul 11, 2010 | Weller Welding Tools
NEED MANUAL FOR Weller soldering station WESD51 POWER UNIT
You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Jan 19, 2010 | Weller WES51 SOLDERING STATION
Garden Logo
689 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
