Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Eco light comes on when I switch on machine but can't change programme and it doesn't work some water still under filter
  • 15 Answers
This indicates water in the base, there is a polystyrene float that operates a cut off switch if water leaks into the base, this could be caused by a leaking pipe connection, or simply by water getting by the door seal and eventually having enough volume in the base te operte the float switch, try tilting the machine backwards if water comes out of the basethen this should cure the problem, but if it recurs fairley quickly you should have the hose connections checked for tightness, can be accessed from the base.
the dishwasher should be isolated from the supply first base tray is secured by 6 screws, the float switch is attached to the base so care should be taken when removing the base tray
Posted on Apr 29, 2010
  • jspark2 Jan 25, 2011
    Also, check the collar under the bottom rotating arm inside the dishwasher. This can come loose and allow water to leak out and operate the float switch. Let things dry out, at least 24 hours, or you may burn out the pump motor.
Check the outlet pipe under the pump for splitting!!!
Posted on May 15, 2010
My washer dryer stops in mid washing cycle and pause button flashes. Will not move on until I reset it
you could call a repairman of course . noone can assist you with no make/model listed .
Oct 16, 2015 | Washing Machines
Why does the eco light flash when i set a programme
My Eco light was flashing fast ,and the drain pump was running continuasly.It turned out at the drip tray was full of water and micro switch add activated . i tipped the machine forward drain the water off the machine as be working fine since. PS dont know why drip add so much water in it, unless theres a leak. ???
Mar 05, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Our F&P DD601V2 double dishdraw is showing error 'U3' and the water does not totally drain out after a cycle, any ideas? Thanks
This applies to all DD601 and DD603 dishdrawers.
U3 is either one of the following:
- Drain pump is blocked.
- Drain hose is blocked.
- Sprayarm or rotor not turning freely.
- Motor electronics have failed.
- Machine set to 'LP' on a high pressure water supply.
Often it's just the last one, "Machine set to 'LP' on a high pressure water supply.", as this can be unintentionally changed by a user from an uncommon course of events. Sometimes, due to the technical design of the way the buttons work, if water bridges the 2 "Programme" and "Eco" buttons (inside on the top right of the tub), pressing either one, or both, (or just having your finger in the water) for longer than 5 seconds brings up a special mode that a user, in their ignorant attempts to get out of it, can erroneously change the pressure setting, subsequently causing a U3 error. It happened to me once when I was cleaning the machine, wiping around the Programme buttons.
To change to the proper High or Low Pressure settings:
1) LCD Display on. Hold the Programme and Eco touch switches simultaneously for 5 seconds.
2) Machine beeps and "HP" or "LP" is displayed in the LCD.
3) Push the Start/Pause button to toggle between them.
4) Push the Power button when correct selection complete.
Apr 07, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishlex global 300. ECO light flashing.
if that fails then try emptying the over flow try found behind the kick panel below the door. 2 phillips screws will be found either side under plastic screw covers, behind kick panel you will find the cover for all internals remove a total of 6 screws from these covers, then with a torch you will see the internal workings of the machine. located at the bottom of it all is a small kidney shaped tray that may have some/alot of water. this is the over flow tray. empty by soaking up the liquid with a sponge. reassemble then try starting it.
Jan 16, 2009 | Dishwashers
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Mar 24, 2008 | Dishwashers
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 | Dishwashers
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
498 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
