Question about Asrock K8NF4G-SATA2 Motherboard
I have this problem... when i disconnect power cord from comuter it's bios forgets settings. Any comments? I've changed mobo battery and running latest bios version
  • 154 Answers
Motherboard is bad
Posted on Apr 23, 2010
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
I forget bios password.
THERE IS A BATTERY ON THE MOTHER BOARD . TAKE THE BATTERY OUT AND POWER ON THE MB FOR A MOMENT. DISCONNECT THE POWER SUPPLY AND INSERT THE BATTERY BACK. BOOT YOUR SYSTEM. THIS SHOULD HAVE SOLVED THE PROB. YOU NEED TO SET THE DATE AND TIME INCLUDING THE DESIRED BIOS SETTING.
REGARDS.
PLZ. DON'T FORGET TO RATE THIS COMMENT
Jul 07, 2011 | Computers & Internet
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Kn8 SLI mobo will not run.
hey.
1. I strongly suggest you clean the dust off your motherboard and other internal components, it is possible that may be culprit if nothing was changed since the last time you used.
2. if something was in fact changed and cleanning does not resolve issue try the following to recover the hardware default status, and then making the motherboard work again:
Step 1. Switch off the power supply unit and then switch it on again after one minute. If there is no power switch on the power supply unit, disconnect its power cord for one minute and then reconnect.
Press and hold the <Insert> key on the keyboard, and press the power-on button to boot up system. If it works, release the <Insert> key and hit <Del> key to enter the BIOS setup page to apply the correct settings. (load default settings and save changes and exit)
If the situation remains the same, repeat the procedures in Step 1 for three times, or try Step 2.
Step 2. Switch off the power supply unit or disconnect the power cord. Open the chassis cover. Locate the CCMOS jumper near the button battery. Change the jumper position from default 1-2 to 2-3 for one minute to discharge the CMOS data, and then put it back to default 1-2 position.
Close the chassis and switch on the power supply unit or plug in the power cord. Press the power-on button to boot up system. If it works, hit <Del> key to enter the BIOS setup page to do the correct settings.
If the situation remains the same, try Step 3.
Step 3. The same procedure as Step 2, but while discharging the CMOS data, pull out the ATX power connectors from motherboard and remove the button battery during CMOS discharge.
3. try replacing the powersupply
Dec 25, 2009 | Abit KN8 SLi Motherboard
Intel D865GBF mobo won't start with battery installed
clear the bios ... with the power fully disconnected...
then reset the bios to the correct features for the system arrangement..
need more help???
Sep 28, 2009 | Computers & Internet
Machine doesn't power up
Remove and reseat all memory, power and processor.
Check your power supply and if good check the board for bad Caps.
Sep 20, 2009 | Abit KV-85 Motherboard
Have forgotten password and need to change to a new one.
Bios password or windows password
if bios password
  1. Turn off power
  2. disconnect power cord
  3. open case
  4. remove button cell battery
  5. press power on button to dissipate any voltage
  6. put button cell back in
  7. plug in cord
  8. reboot
  9. cmos checksum error, enter bios, set date,time,etc
If windows
password is unknown
  1. press F8 on boot
  2. select safe mode
  3. log into Administrator account
  4. no password
  5. go to start, settings, control panel, users,
  6. select your account, select change password.
Apr 01, 2008 | Computers & Internet
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
Asrock K8NF4G-SATA2 Motherboard Logo
103 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
