Question about HP Deskjet D2360 InkJet Printer
Printer not printing
Its set as a default i have re installed the driver. its plugged as a usb. what else could be wrong??
    Guru:
  • 377 Answers
Hi dear
in control panel , choose printer & fax
delete the old printer first.
try to re connect printer again
oke
Posted on Mar 23, 2008
SOURCE:
Scanner & Printer X3470
You first need to download and install drivers here:
DRIVERS & DOWNLOADS -- Lexmark.
Unplug printer before installing drivers.
Aug 31, 2008 | Lexmark X3470 All-In-One InkJet Printer
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
Prints gibberish
First test a different USB cable. A faulty data cable can cause the problem.
Once you are sure the cable is OK, reinstall printer software. A corrupted or wrong printer driver software is common cause for this kind of problem.
You can reinstall software using printer disk, or download from manufacturer website.
Start software setup with printer USB not connected.
Sep 10, 2009 | Office Equipment & Supplies
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
HP laserjet 1300n won't print duplex from vista
in the printer driver setting there is option to turn on manual duplex printing.
Go to printer driver properties go to printing default under printing default there is a option called finishing in finishing print on both sides is mentioned select that option and i m sure it should work
May 03, 2009 | HP LaserJet 1300n Printer
My Brother copier printer DCP-IIOC, will copy but won't print, in fact the computer won't recognise the printer, the usb cable is fine, what is wrong or can you help me please?
Try this :
First check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Apr 25, 2008 | Office Equipment & Supplies
Printer Fault
USB port is set wrong on driver...
Unplug usb, delete driver, reinstall driver, plug usb in only when directed by install
Jan 15, 2008 | Brother DCP-7020 All-In-One Laser Printer
HP Deskjet D2360 InkJet Printer Logo
20 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
