Question about Canon PIXMA iP1700 InkJet Photo Printer
PIXMA iP1700 A paper got jammed and I pulled the paper out, now it says that it is still jammed.
  • Anonymous May 22, 2008
    AFTER THE JAM .THE PAPER IS STILL JAMING UP. WHEN THE PAPER IS PULLING IN TO THE PRINTER, IT STARTS WADDING UP ON THE
    RIGHT SIDE . THE LEFT SIDE IS NOT GOING IN THE PAPER TRAIL .
    I UPLUGED IT , TURN OFF , CHANGED PAPER , BLEW IT OUT WITH
    AIR !!!!!!!!! SO I'M DONE HELP HELP!!!!!!!!!!!!!!!!!!!!!!!!!
    Guru:
  • 377 Answers
Hi dear
turn off your printer,
try with this metode
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
oke try to print
Posted on Mar 23, 2008
Cannon Printer PIXMA ip1700 Paper Jam-I checked the feeder and everything I know but it still comes up paper jam. Need help,Donna
Hello and Welcome
I am Angel Bird and i will be assisting you regarding the issue
If you are facing this error their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it :
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution was helpful for you.
Please give me token of appreciation as FOUR THUMBS it if it helps you.
Thanks & keep using FixYa
Apr 01, 2011 | Canon PIXMA iP1700 InkJet Photo Printer
Error says paper jam but no paper in it
There may be a sensor that is messed up. turn off and unplug the printer and let it sit for a minuet or two. Then plug it back in and check to see if the error persists.
Jan 08, 2011 | Canon PIXMA iP1700 InkJet Photo Printer
I have a pixma 1700 (iP1700) cannon printer that
List of things to try when receiving paper jam error:
1) Paper is indeed jammed internally: Power Off. Open the cover and remove the paper or scrap carefully. Do not touch the internal printer parts. Close the front cover.
2) Load paper correctly according to your manual. Use recommended paper and obey load limits.
3) Foreign objects in printer: Power Off. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (Remove it by hand or with tweezers). Open the front cover and confirm that there is not any foreign material in the unit. Avoid touching the inner workings of the machine.
4) Reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
If all of these suggestions fail, your iP1700 may require repair service.
Dec 27, 2009 | Canon Office Equipment & Supplies
Printer jams
try to clean the printer rollers with acohol it should work
Jul 23, 2009 | Office Equipment & Supplies
False paper jam
check front and rear paper sensors. Maybe they damaged. Clean optical sensors.
Nov 17, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Nov 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Open Questions:
See all Canon PIXMA iP1700 InkJet Photo Printer Questions
Canon PIXMA iP1700 InkJet Photo Printer Logo
378 people viewed this question
old marine
old marine
