Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
I have an tappen electric range the burners work but not the display not oven. I is brand new and has a brand new cord also. I checked the breaker box and no fuses are tripped. What could it be?
I have a ken more Range but is digital to set up, I have hard time to turn the oven on some body can help me?
thanks
Posted on Nov 28, 2013
  • Kenmore Master
  • 12,061 Answers
I have a Kenmore 790.96224 electric range and the burners and oven do not work, but the clock is working. how do i fix?
Try replacing ONE stovetop burner and see if the new one works. If it does, replace more stovetop burners. If the new ones all work, replace the oven burners.
If that first replacement stovetop burner STILL doesn't work, don't replace any more. Instead, check (or have checked) the circuit breaker for the range. It may get power from a second source to power the clock.
Jul 26, 2014 | Kenmore 96222 / 96224 / 96229 Electric...
Surface work but display and oven do not
Bigejpp, start with the basics, On the back of the range where the cord hooks up see if you have the correct power. Three terminals, you should have 120V from each end to center and 240V across the two outer terminals on the terminal block. If you don't have this, the problem is in the breaker. If you do have it, remove the upper back panel and look at the board. You will see L1 L2 and L2 out which goes to the elements. Test for voltage at L1, should have 120V. If you have power to the board and no display, the control is at fault. This is for a 790.95320 electric range. If your model does not beging with 790, most electric ranges operate in a similar matter. Catriver.
Jun 14, 2007 | Kenmore 95320 / 95321 / 95322 / 95324 /...
2 burners not working, display or oven not working
Hello - I understand that the range has no display and experiencing issues with the burners not working. Please try resetting the unit by either unplugging it or flipping the breaker off. Wait approximately ten minutes and turn the unit back on. Try setting the time and if it proves to be ineffective, the unit may possibly have a faulty EOC, defective wiring harness, or damaged cord. I would suggest contacting a professional to move forward accurately.
Nov 09, 2012 | Frigidaire FEF336BC Electric Kitchen Range
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
My oven and burners dont work
you have a power problem check your breaker first then if thats good turn it off anc check where the cord hooks to the range your only getting 110 volts to the range let me know what you find
Mar 12, 2009 | Whirlpool Accubake RF362LXTS Electric...
GE JBP64 Radiant Range - won't work
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker.
Aug 31, 2008 | GE Spectra JBP78 Electric Kitchen Range
Maytag electric range will not work
you have a house power promblem turn off the range at the breakers and start at where the cord connects to the range check it there then go back to the breakers all the eyes are on their circutes so it has to be at the power source feeding them
Jul 14, 2008 | Kitchen Ranges
Power lights come on burners do not, oven does work
then check your voltage if you have 220 at the out let (and don't assume you do check it!) if you have 220 there pull the back cover off the cord and see if the cord is loose or burned . but before you pull the range out in this situation turn off the breaker for safety in case the cord has burned out all theese componts are on separate circuit's and only thing that will stop them all is a power problem of some kind if you dont find nothing turn the breaker back on and try the range again if the cord is burned this is caused by improper tightening of the cord during instalation and there is no fault in the range install new cord properly and it will be fine
Feb 17, 2008 | Hotpoint RB525BC Electric Kitchen Range
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
313 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
